A many sided situation, the older model projectoin tv I'm need some help. on remote cntrl accident color and picture quality are now screwed I made it worse trying to correct it though may have a chance at get it normal before the this happened, I at least hope. if i guessed where to start it be convergence adjust, the trouble in my challgenge must also struggle w/ this: the remote control device does not have a functioning right arrow cursor button, every other function works effectively as normal. so all things that need to use the right arrow button won't be remote cntrl possible when I go to fix this problem, and it does sure make this situation stuck. how shall either fix the trouble manualy, or the remote problem enough in order to next solve the tv woe I have. thanks i could go into more detail ( manual specs etc), should any one have a idea how it helps, is old model tv so many model#'s I wouldn't know whichever is the one I need the help for, but if it does really help I look at the set and find product name design i guess. Thanks for any good idea's.
Posted by dull_bananas on
John Street
    Guru:
  • 513 Answers
I would go out and get a replacement Universal remote with menu keys. Set the code for your TV and try that. You may need to activate the menu with the old remote and then do the adjustments with the Universal remote. Older sets work with most Universal remotes real well. make sure you get a remote that supports MENU functions.
The customer convergence controls affect red and blue, with green being the unmoving reference. Cust controls are easily adjusted back, but if you have moved the tech adjustments...
Posted on Apr 04, 2010
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
I dnt have a remote for the tv also their is no menu on the front panel wat can i do
You should have cntrl buttons on your tv on the side, top or bottom of tv with INPUT select. If its an older tv it might have a cable / antenna switch. Might have to look around.
Hope this helps
Feb 11, 2015 | Toshiba MV19N2 19 in. TV/VCR Combo
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Rca tv broke
Need the actual model number to help you as it sounds like the ITC222 or ITC222A flyback error.
May 27, 2009 | Televison & Video
Television picture issues...
I had the same problem when I accidently hit the remote. If you are hooked up to cable make sure INPUT is on the correct setting -- AV, S-Video, YPbPr1, YPbPr2, VGA, HDMI1, HDMI2, ATV & DTV (see button on TV or remote). Hope this solves your problem.
Jul 27, 2008 | Astar LTV-3201 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
