Dishwasher is only a couple years old. Tenant says it takes two and one half hours to run a load of dishes
They probably aren't running the hot water at the sink before starting the dishwasher. You know how it takes time to get hot water at the tap when you turn it on? well the new dishwashers use such little water, that they will fill with cold/warm water, and try to heat it up to 170+ degrees before continuing the cycle
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
Check water supply to the machine. May be clogged and flows in low stream. Check the inlet water filter at the machine end
