If that doesnt work, unscrew the back and check the wires, it is common for the saudering to be faulty in most guitars. Also make sure the the input nut is tight b/c the more play there is, the more chance the sauder is going to break.
First check the cable. If that works fine on another instrument then i would check the input jack next. Also try turning the volume knobs. You may have a dead spot on the potentiometer.
The bridge pick up has stopped working
What exactly do you mean by "distortion"? Does it sound similar to radio static, or is it a crackling hum?
