Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
Hooked it up with water started engine and no
Stored in heated garage all winter and when I hooked it up with water started engine and no water pressure. Pulled off high pressure hose and still no water came out. Did notice a pasty sludge on the low pressure side. Engine runs well, water pressure is good. What is the problem?
Posted by conconwright on
Anonymous
  • 332 Answers
Your water system is plugged with "gunk"
You will need to slush it out with water and air pressure if you can until it runs clear
Posted on Apr 04, 2010
How do I winterize Gas high pressure washer.
Pump will freeze in cold weather from water left in sump. Get it running and instead of hooking it up to a water hose, use a short length to take a gallon of so of antifreeze.
2answers
Engine working fine, but water not coming out
Couple of things, is the water supply good? if that's a yes, then check to see if there is a way to engage / disengage the pump, some models offer that, if engaged and good water supply, then it has to be your pump
1helpful
Engine runs but only a steam of water comes out of gun with trigger on. washer is stored in a heated garage in winter.
you need to remove and clean the unloader valve. The way this valve works is when you release the trigger the pressure is diverted around the pump through the inlet side so you don't cause damage to the pump. This valve is usually located next to the discharge pipe on the pump where your pressure hose hooks up to. Remove and clean. Be sure to clean port that you remove the valve from also. Use carburetor cleaner. Lubricate the valve with a light coat of lithium grease. This should cure the problem. If not let me know.
1helpful
Husky pressure washer 80432. 1 year old. worked before the winter. no pressure this summer. honda engine runs fine. replaced the pump from the bottom of the engine down... still doesn't pressurize. ...
Check the inlet strainer where the water supply hose is attached,this is located just inside the coupling where you hook up the water hose.
Jul 30, 2010 • Garden
4helpful
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
2helpful
3answers
Output pressure same as input pressure.
try taking the pump apart and cleaning it prob got a clogged port
Top Briggs Garden Experts
Mike
Marvin
Marvin
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
