It all depends on what kind of connections you are using. In most cases you set the dvd recorder to input 1. Then use the yellow,red & black or white out puts from the vhs player to hook up to the number 1 input on the dvd recorder. hit play on the vhs & record on the dvd recorder at the same time. Do not forget to put a blank dvd in the dvd recorder? also for the best copy set your dvd recorder to XP for a 1 hour recording for a 1 hour or longer recording set the dvd recorder speed to SP. You should have the dvd recorder hooked up to a Tv so you can monitor the recording progress. This should work out as long as the recording you are copying is not copy protected. Good luck.
BE CERTAIN OF THE KIND OF DVD DISKS IT SUPPORTS. My experience is that the kind of discs while you would think would not make a difference actually do make a big difference depending on the equipment you are using. I just transferred 15 vhs tapes to DVD and realized that the machine only took a few formats luckily it was the one I was using, but not all formats may be compatible. There is a difference between DVD+R and DVD-R as an example.
It depends on the specifications of the DVD drive in the laptop. Go to the website for you laptop manufacturer and look up the specifications. You also have to have DVD playing software. It is was not always included with the Windows operating system, although some kind of player may have been packaged with your computer when sold. DVD-RWs are recorded at slower speeds, which makes bigger dots and make not work with all DVD playback drives.
DVD-R and DVD+R should play once recorded and finalized. RW of any kind is iffy and must be tested to see if they will work.
I don't think any dual layer DVDs will work, but I could be wrong. If you're taking about recording DVDs on this, it's not a DVD recorder as far as I know.
There are different kinds of DVD recorders and different kinds of recordable DVD disks. Your disk must match the format of your recorder. (eg DVD -rw, dvd -r, dvd +rw, dvd +r). Look on the front panel of the emerson recorder and see what emblems are printed on it. Your dvd must match the kind. Also, if a dvd is of the -r or +r variety and has been finalized you cannot overwrite/rewrite to it. (From a quick web search it appears your dvd uses dvd -r.)
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS .
NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN
TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK .
BEST REGARDS , blc7772001
That will write on -R or -RW ONLY ... for +R or +RW disks, it can read but not write.
You can see this on the recordable media section on this page:
http://www.dealtime.com/xPF-Sanyo-Sanyo-DVD-DRW1000-Recorder-Hi-Fi-VCR-Combo
