Question about Toshiba Equium 100 PC Desktop
My Toshiba Equium laptop will not read CDs or DVDs
Posted by dvoreilly on
Robert Wheeler
    New Friend:
  • 71 Answers
Is CD/DVD showing in my computer?
Are you reading retail or homemade CDs?
Use retail to test reader, any will do.
Not all homemades work in all readers.
Look here:
http://repair.laptopsinfo.net/How_to_open_toshiba_equium_laptop
Posted on Apr 04, 2010
Dvd rw wont play dvds or cds my lapyop is a toshiba equium l40
Update the drivers and check, also try and use a lens cleaner on the drive and if the DVD does not read then the drive is faulty and must be replaced.Finally you can check this on another PC to confirm.
Jan 07, 2012 | Toshiba Computers & Internet
My toshiba equium a200-1v0 will not burn to dvd
Does it read CD/DVDs fine? If so, the laser head for writing data to the discs may be defective. Also, keep in mind that when CD/DVD drivers start to fail, they may be able to read/write to CDs and not to DVDs or vice versa.
Otherwise, go to "Start" and right-click on "Computer" and select "Properties". Then, on the top left corner of the window, go to "Device Manager". Expand "Disk drives" and make sure there is no exclamation mark or question mark on the CD/DVD device. If there is, then either the driver software is missing/corrupt or the drive is defective. If no CD/DVD drive is listed, then it is not being recognized as being installed then check all of the cables to make sure nothing's loose, otherwise it is most likely defective.
May 05, 2011 | Toshiba Computers & Internet
Toshiba laptops
Toshiba laptops, like any other laptops, can read all cd regardless of the manufacturer. It is unlawful for toshiba to design a laptop that can only read toshiba recovery cds. You can reinstall your OS on a toshiba using a dell disc.
Enjoy the power of a PC
Feb 14, 2010 | Toshiba Satellite M115-S3094 Notebook
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
My Toshiba Satellite A205-S5803 will no longer read or write cds
Try getting your recovery DVD's out --- put Disk 1 into the drive; choose "Install Applications and drivers" --- click Next and follow the directions.
Oct 08, 2009 | Toshiba Satellite A60 Notebook
After I reinstalled my pc, the toshiba dvd-rom (sd-c2502) only plays cds, not dvds.
Try re-installing your the driver for your dvd rom. Then try to put different dvds and check if it can read from your drive. If problem remains, I suspected it's your dvd rom is faulty
Jun 02, 2009 | Dell Computers & Internet
My laptop still cant read cds or dvds
Try going to the site for the manufacturer of the cd/dvd drive and download/ install the latest driver. Also look in devive manager to see if you have any conflicts (yellow ?)
Feb 11, 2009 | Toshiba Satellite A135-S2386 Notebook
DVD/CD Drive Does not recognise copied CDs
It seems to me that ypu have not copied correctly..try to use NERO for write CD/DVD for best result...
Dec 01, 2008 | Toshiba Satellite A60-S1561 Notebook
Dvd rom not reading dvd while reading cd properly!!!
The demands on the drive differ greatly for reading CDs & DVDs.
This is a common problem since alignment of the drive is very critical for DVDs and often fails first.
I don't offer much hope, but you might buy a special disk for cleaning optical drives; sometimes they will help.
This article has some tips that might be of use:
http://www.smartcomputing.com/editorial/article.asp?article=articles%2F2003%2Fs1409%2F10s09%2F10s09.asp
Aug 03, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Equium 100 PC Desktop Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
