When i turn the tv on i have to scan for channels.i then can watch any channel i want but if i turn the tv off i lose all the channels and have to rescan the next time i turn the tv on.how do i get the tv to retain the channels?
If you turn the TV off by any other means than using the TV's power button you will lose the saved channels.
I think that this only applies to the first turn off after the channel scan.
In notes at right. Emerson LC195EM87 Owner Manual Auto Channel Scan Language Selection
hello are you using a digital antenna, cable or satelite reception? you need to run your "set up" and scan for channels either automatically scan or manual scan, recomend a auto scan for all channels both digital and anolog, these tv will scan and save or store the channels but you need to run a channel scan first,
(even if your using a cable box or sat box)
back when we had the older anolog sets you could just plug it in and watch but with these new digital circuts need to scan and store the channels in before you can watch the broadcasts,, try that let me know what happens. hope this helps
Depending on the signal strength of those channels on the days you do the scan your tv may decide that it is not a good enough signal for it to even bother programming into your normal channel list.
The weather will honestly have a lot to do with pulling in over-the-air broadcasts.
Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
