HP LaserJet 1020 Printer Logo
Question about HP LaserJet 1020 Printer
HP 1020 Laserjet giving a single Heavy black line horizontal
Getting a Single Heavy black line horizontal linacross every page
Posted by hughmcgarry on
Anonymous
    New Friend:
  • 4 Answers
REPLACE PCR BLACK ROLLER IN YOUR CARTRIDGE
Posted on Apr 16, 2010
2answers
Why do i get a black line through my print outs?
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem:
- Replace the ink cartridge
- Check the flexible cabling for continuity and for short circuits between adjacent conductors
- Exchange the control board for a good one
- Finally check the power supply
Good Luck
2answers
HP Laserjet 1020 printer prints pages with vertical black
i think your installer is wrong you need to download the best drivers
i hope i can help you
Print came only single dotted line on paper
u change the printer software, then u check.
1helpful
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
1helpful
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
2helpful
2answers
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
1helpful
My Hp 1020 printer is printing full black pages.....
is this a laser printer? have you replace the toner cart?
Clive
Clive
Ben Johnson
