I cant use g-pen tablet genius 450 in Ps cs4 with most of tools : eraser,brush,pen...It works to select tool but doesnt work to draw with.For example : with pen tablet I can open photoshop , open photograph,or set up new document and use marquee tool to make selection,but cant use brushes,erasers,pen but I can use same tool with my mouse (brush,eraser,pen).In the same time I can use g-pen tablet genius 450 with corel products : corel draw x4, paint shop pro x2,corel painter 11 perfectly.I have reinstaled driver and PenSuitePro for a several times and doesnt help.
I use windows xp,sp3 OS on fujitsu siemens EM 5535.
Thanks in advance !
In photoshop, press F5 to bring up your brush control window. Under shape dynamics and other dynamics and any other brush attributes you wish to control with your pen, make sure that control is set to "pen pressure" in the drop down menu. Hope that fixes it for ya.
Hi, I had the same problem with Photoshop CS4. I'm now on the previous version (CS3) and it works fine, just be sure to donwload the last drivers on www.geniusnet.com.tw.
Double click pen tablet icon in system try,then open button tab,under button command change Button Name from Pen Tip ( Default ) to Barrel Button 1 , click Ok and in Ps from Window meni select brushes,click Shape Dynamics (letters not square) and from shape dynamics dilog move Minimum Diametar slyder to right ( 100 %).This solved problem to me.I hope it will work for anyone else.I run xp sp3 on Windows.
1. Go to: http://www.geniusnet.com/2. Click on "Service & Support"3. Click on "Drivers"4. Click on the tab labelled "Tablet".5. Find your tablet model on the page.6. Select your platform from the drop down menu opposite to your tablet's model.7. Click "Downlod", then click on the driver's file name in the window that will pop up. The download of your tablet's driver will start.
Try here, this is the company's website, I downloaded there the version of the driver for XP, once you're in the site, click on "product", then on the section "tablet", once there you just have to search for your tablet model and click on "more", it will sen you to the specifications of your tablet, and there you will find the download section, you just have to pick the operative system you're using and then click on "download" to get the driver you need. http://www.geniusnet.com/geniusOnline/online.portal
You need to use a bigger brush. the highest level of pressure is the full brush size (i.e, it won't ever make it bigger than the biggest size you select). It seems to work percentage-wise from that (half-pressure=half-size).
Also, make sure the setting are correct in the brush pallete (check shape dynamics and make sure the Control: is set to "Pen Pressure). Note that you can change it to control other things instead of size (I frequently use it on opacity to do sketches in a pencil style, and it works really beautifully).
Oh yeah, make sure you change the battery too. Mine came with it pre-installed and there wasn't enough juice, so I put one of my rechargeable's in and it worked fine.
