Colored lines have appeared on the right side of our 46 inch Vizio LCD TV. We have tried the Vertical and horizontal hold to move them out of the viewing screen but this does not work.
I hate to give you bad news but I believe this will be a panel issue and it's not going to be fixable. You can try a different tcon board but I don't think it will help
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
