It started going out. at first, when I restarted my PC and it would come back on. Power light is on, but the screen does not come on. The screen flickers from the right side of the monitor. It looks light gray
This is a typical symptom of a failure of the capacitors on the power supply board. When the filter capacitors go bad the power supply can not start up correctly so you get flickering or even no display. You can repair this unit by replacing the bad capacitors and a fuse on the power supply. This is an easy repair, it just requires a little soldering. Here is a lin to additional information on which capacitors need to be replace and also here is a picture of the power supply board with the capacitors and fuse circled.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
Sounds like the backlight or backlight inverter
