Question about Brother Office Equipment & Supplies
Brother ax-26 typewriter "cover open"
Brother ax-26 typewriter shows "cover open" when it isn't. Tried opening and closing cover several times - no change.
Posted by dianeswebstu on
  • Anonymous Mar 13, 2014
    Electronic typewriter displays message "Cover Open" when turned on, buttons are inoperable because of error message. I replaced the ribbon, but the cover is completely closed to the best of my knowledge. Any ideas?
Anonymous
    New Friend:
  • 61 Answers
Small projection under lid has bent or broken. Wedge something in the hole to operate micro-switch. If not effective the maybe micro-switch has moved or is faulty. Short out the wires to micro-switch in that case.
Posted on Apr 24, 2010
Need user manual for brother ax310
Brother has some of their manuals on their support site: http://www.brother-usa.com/Support/ . I found FAQs for the AX300 and AX350, among others listed. However, no manuals were available. The manual for the AX-325 is available, http://www.brother-usa.com/VirData/Content/en-US/Typewriters/Consumer/UsersManual/UM_AX325_GX_6750_EN_5674.PDF .
I did find the manual for the AX-310 in German here: https://preview.u-manual.com/preview-manual-for-free-212176/others-brother-ax-310/page-1.html .
I hope these manuals help. Brother didn't change their typewriters significantly between some models.
Jun 15, 2017 | Brother Office Equipment & Supplies
I have a brother AX-25 and when it is turned on it will make a fast clicking noise and then just beep no matter what until it is turned off. What is wrong with it and what do I do?
Turn off the typewriter, open the top-cover and inspect the area around the carrier for any damage or foreign objects.
2. Move the carrier towards the center of the machine.
a. When moving the carrier manually, it should be difficult to move, but it will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connected properly.
3. Remove the ribbon and inspect the cartridge for damage. Turn the colored knob on the left side of the cartridge to remove any slack from the ribbon.
4. Check the correction tape to insure that it has not become tangled ordamaged.
5. Close the top-cover and restore power to the machine.
If the problem persists, your machine may require service.
Jan 23, 2014 | Office Equipment & Supplies
Brothers ax
a. When moving the carrier manually, it should be difficult to move, butit will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connectedproperly.
Dec 12, 2013 | Brother EM-430 Typewriter
My daughter just got a used Brother AX-12 typewriter but it doesn't have a manual. Where can I find a manual?
yoYI would so to ask.com and type in manaul for brother ax-12 typerwriter.
Or, you could just google Brother Ax-12 typewriter and then click on the information and the manual will probably be listed.
Mar 30, 2011 | Brother GX-6750 Typewriter
I need the owners manual for my Brother Electronic Typewriter AX-12
Hi
On the Brother site, there is one available for the AX-20.
Maybe it is simlar to your machine?
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_AX20_EN_1594.PDF
Hope this helps!
Nov 02, 2009 | Brother SX-4000 Typewriter
155 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
