www.genautoinc.com/6-common-reasons-your-
car-
wont-start.php
Jun 25, 2015 - If no dashboard lights come on when you turn the key in the ignition, that's a ... You can also check whether your windshield wipers, radio, heat/AC or headlights work. ... If your car can't pump the gas to fuel the engine, it won't start. ...the starter works and the fuel gets to the engine, but still nothing happens.
www.dirtcheapquotes.com/Mechanical/why_
car_
wont_start.htm
Your online resource for auto, truck or motorcycle insurance. ... Starting Problem # 1: Engine Won't Crank At All. Scenario: You turn the key, but nothing happens: And by nothing, we mean there ... Jump-starting the battery should get the engine to start. ... Incars with electronic fuel injection, you should hear a light hum a few ...
www.familyhandyman.com > Skills
If you turn the car key and your car won't start, don't give up. Before you call for a tow, try these seven simple tricks to get your car started again. The only tool ... To heat up the battery, terminals and starter, try the "key cycling" trick (photo 1). But if the domelight stayed bright when you turned the key, move on to the next trick.
SAME ISSUE, NOTHING , NO HEADLIGHTS, NOTHING CLICKING AT ALL, THIS IS THE FIRST TIME THIS HAS HAPPEN, SINCE I BOUGHT THE BIKE NEW IN 2000. AND IT IS A 2000 ROADSTAR..
THANKS ANYWAY
CHECKED ALL FUSES, THEY ARE ALL GOOD, I`M STUNNED.
