Question about HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 Multifunction monochrome printer,copier,scan and fax. This machine will warm up, and after it reads "scanner lamp warming", the scanner lite lights up, the carriage moves back and forth, then goes to home position and vibrates while moving slightly back and forth. I've replaced the scanner formatter and that did not fix problem. Should I chuck the machine or is there another part that is easty to replace, and cheap?
  • HP Master
  • 1,684 Answers
This type of problem is usually caused by dirty mirrors in the scanner. After a few years of use the mirrors and lenses in the unit will get a fine coating of dust particles on them. The dust interferes with the scanner initializing the optics. When this happens the unit displays the Scanner warming up message on the screen and keeps trying to move the scanner assembly to get a good reading from the pickup. To solve the problem you will need to disassemble the scanner portion and clean all of the mirrors with window cleaner and a soft cloth or q-tip. To get dis-assembly guides just do a google search for the 'scanner warming up' error.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 04, 2010
6ya staff
SOURCE:
Hp fax machine does not picks up incoming fax calls automaticly
check your settings to ensure that it is set to automatically answer fax calls. Also ensure that if you have distinct ring tone service that you have that feature enable properly for the ring tone that denotes faxes.
Sep 06, 2014 | HP LaserJet Pro M127FN Laser Multifunction...
Scanner bulb warnning
The 'scanner warming up' error is caused by dirty scanner optics. What happens is the scanner initializes the lamp and starts reading the scanner pickup waiting for the light to get to a certain brightness level. When the optics get dirty from dust or smoke then the light getting to the scanner pickup is reduced so the unit thinks the scanner bulb has not reached the correct brightness so it says wait. What you will need to do is dis-assemble the top portion and clean the scanner optics. We have a step by step guide to do this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ This should get you back going again.
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 16, 2010 | HP LaserJet 3330 All-In-One Printer
Hp laser jet 3330 will not reset with acquired instructions and bulb warming message stays on.......i've tried to unplug unit....stays the same. cancel button also stays lit
You need to take apart the top and clean the scanner bulb and mirrors, if cleaning does not help then you need a new scan assembly. Usually costs more than a new machine.
Jul 14, 2009 | HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 MFP
I have that oranage triangle light blinking as warm up message continues I also had power loss I have taken the plug out and will wait a while and try again. I still get now scanner errors using ubuntu..
May 16, 2009 | HP LaserJet 3330 All-In-One Printer
Service tech seeks service manual in .pdf for hp laserjet 3330
Any HP printer. All parts diagrams:
http://partsurfer.hp.com/cgi-bin/spi/main
Apr 02, 2009 | HP LaserJet 3330 All-In-One Printer
HP 3330 Scanner is very slow
PDF files are notoriously slow to print. You might invest in more printer memory.
Jan 16, 2009 | HP LaserJet 3330 All-In-One Printer
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
My printer takes a long time to warm up between uses.
Only the way to solve this problem is to change new flourescent lamp. I have encounterd it before and solved by changing flourescent lamp. But to change the lamp is a bit complicated job.
Nov 12, 2007 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
157 people viewed this question
Ekse
Thomas F. Schneider
