Question about Technics Audio Players & Recorders
Erratic volume from new turntable thru used amp
Just bought used amp. volume fades then comes back by itself. sometimes happens every few minutes. sometimes no problem for 1/2 an hour or so. sometimes some static . only two front speaker channels work. turntable and speakers work OK with a different system. turntable is only component connected to amp.
  • 1 more comment
  • Anonymous Apr 17, 2010
    I returned the amp (Tehnics su-g75) to pawn shop. They told me volume change caused by using surround sound setting with only the two front speakers connected. They also told me that I had fried one channel when I connected the speakers with the power turned on. They gave me another amp that works fine. No extra charge so problem solved. Thanks for responding.
    macr590
  • Anonymous Apr 18, 2010
    See comments added Apr. 17. Problem solved. Thanks.
    macr590
  • Scott Frye
    Scott Frye May 11, 2010
    Hi... What model amplifier is it?
Scott Frye
    Genius:
  • 1,175 Answers
Glad to hear you got things worked out
-Scott
Posted on Apr 18, 2010
1 Related Answer
Grubhead
Grubhead
  • 5700 Answers
SOURCE: erratic volume from new turntable thru used amp
First detirmine if it is only the turntable that is causing this problem, by connecting something else to another terminal. If that works fine it will be the cartridge preamp that is causing the problem. From what you describe it sounds like an IC that is playing up.
If the other device plays up as well as the turntable, I still suspect an IC, but this time in the main pre-amp. The reason I suspect an IC is that by the sound of things both channels are playing up and therefore it has to be somepart that has both channels going in and out of it- thus IC!
Posted on May 10, 2010
When playing records on my turntable, the right speaker often cuts out, almost completely (big dip in volume and a bit fuzzy sounding). It will then come back sometimes, when tapiing, fiddling with a the...
Check the wires to the cartridge, they can come lose and need to be tight. If that doesn't solve the problem check or replace the connecting cables. You can confirm it's not the pre-amp of your amp by just swaping the cables. Then the left speaker should play up. If it is still the right, then there's a fault on the pre-amp. But it could be just bad soldering somewhere. Also take the bottom of the turntable and check the soldering of the cables inside it.
Dec 08, 2010 | Sony PS-LX250H Turntable
Just bought a new Shure high performance stylus for my Technics SL-1200MK2. After a few weeks of use, while a record is playing the volume on the left channel will drop significantly. If I take the...
it could be two things:
1.the tone arm wires that connect to the head shell (blue-red-green-white i think)
2. the needle arm has twisted round
Put it on the other deck if you've got one & see if it does it.
look right at the end of the needle tip,& see if it's straight & pointing down, if not carefully twist the needle arm round until it is,& push it into back in to the cartridge a little bit.
Sep 30, 2010 | Technics SL-1200MK2 Turntable
Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
May 24, 2010 | Televison & Video
May 08, 2010 | Audio Players & Recorders
Receiver fading in and out.
I want to think about this for awhile but first I want to caution you to NEVER turn the volume all the way up and then place your ears near the speakers for diagnosis of an unknown problem. If you inadvertently affect it to come back you can kiss your speakers (and maybe your ears) goodbye.
I'd agree that it is none of your hardware if it affects all inputs, two receivers and multiple speakers.
This sounds like a good one.
The simplest source to use for further trouble-shooting would be FM as it has no external connections, and it's vanilla stereo. Keep It Simple.
"Power bars"? Do you mean like a power strip with multiple outlets and maybe some kind of surge protection? Pare the system down to its most basic form - receiver, front speakers, one power source direct from the wall. What happens? Add components and complexity until the problem returns. Good luck.
Jan 22, 2010 | Audio Players & Recorders
The TV cuts off frequently. The screen is blank & no sound.
It is probable you have a poor soldered connection on the power supply board, hence the erratic timing of the TV going on & off. If you are competent with a soldering iron look for dry jointed soldering on the board. If not have a service engineer take a look at it for you.
Jun 24, 2009 | Panasonic Televison & Video
TV keeps shutting down.
the power relay contacts are burned replace the relay
May 21, 2009 | Philips Televison & Video
Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Aug 24, 2007 | Technics SA-DX940
Speakers fade in and out when listening to music
ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
May 25, 2007 | Dell 5650 Computer Speakers
Top Technics Audio Players & Recorders Experts
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
