Question about Acer Aspire 7720-6844 Notebook
Will non connect to wireless att uverse network. will connect to other wireless networks
Posted by joshcmommy on
Manikandan Raj
    Guru:
  • 825 Answers
Delete preferred networks from the computer...try to scan and connect again...your problem will get fixed....
goto network and sharing center > manage wireless networks > select and delete networks already saved (for vista and win7)
goto wireless network connection > right click >click view available networks>left side click on change the order of preferred networks >select and delete all networks now scan and connect......
pls do rate if its useful....
Posted on Apr 03, 2010
Ethernet (wired) connection to computer works but "wireless" light does not come on and my laptop cannot locate a wireless access point or network device. It has worked in the past but after...
You will need to get a hold of att. They will need to have you unplug the 2wire and then reconnect. They will need to reset the gateway from their end. good Luck.
Sep 07, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Will not connect to my network
no you do not need ascii characters,well you might want to go into the port configuration for your printer,select tcp port,make sure it is checked(it should have a 192.168.etc address ) hit ok try a test print.
good luck
Aug 26, 2009 | Lexmark X4650 InkJet Printer
I can't connect wirelessly with my printer since I got Uverse
i work for att tech. support .. but for DSL
yeah we dont configure printers....
but what you can do is go to the modem interphse
URL....only type in 192.168.1.254 ENTER
and go to FIREWALL then SETTINGS
select DMZ modem or allow all applications
give that a shoot might help.
then see under HOME NETWORK if you see the printer
Jun 21, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
How to set up uverse home network with 2wire gateway
To use AT&T Uverse for a home network, you need to get the AT&T "Homeview" Network Management software. AT&T provided this software in the past freely.
This software must be run on each PC on your home network, and then each PC can see the others. You then use go to My Computer, select each disk drive you want to share, right-click and select Sharing and Security, and select to share the drive. Then go on the drive to the folders you want to share and right-click and set them to be shared. Then the Homeview system will show these are shared folders. You can also share printers on the same network using the Homeview software.
Jun 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Home networking with uverse
Try to run the Windows Network Wizard in each computer on your network.
Mar 04, 2009 | Gateway Wireless-B Router (wbr-100)
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Acer Aspire 7720-6844 Notebook Logo
931 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
