Question about Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer how do i set
Brother MFC-9440CN Laser Printer ..how do i set it to print wireless
Posted by willazz2003 on
Kenneth Brilliant
  • 39 Answers
The only real way to make this printer wireless, is to connect its ethernet port to a wireless router and via the router, send jobs to the printer wirelessly. hope this helps. Cost is about $60-$70 for the router.
Posted on Apr 04, 2010
My Brother mfc 9440cn is printing a ghost image. how do you fix this?
The most common remedy is to clean the drum unit, but you have replaced that. Try cleaning the corona wires, p144 here
http://www.manualsprinter.com/manuals/brother/Brother_MFC-9440CN.pdf
Jan 11, 2015 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer knocking noise on startup and printing
Throw that piece of garbage out and get an HP or Samsung. One of these has plagued my office for years and I've spent countless hours plotting its demise. Worse than useless: unreliable.
Mar 25, 2014 | Brother MFC-9440CN Laser Printer
I have one line on the page that the ink does not set on my Brother MFC-9440CN. All the other ink sets, but this one line doesn't and it "smudges" when you run your hand over it.
I've just bought a brother printer and find that when I print onto cd labels i've used before, the ink is not setting. I have never had this problem before with these labels, so now am concerned that the only new addition is the printer. Why should this happen? Is it the ink they use?
Jul 23, 2010 | Brother MFC-9440CN Laser Printer
I just purchased a brother mfc-9440cn how do I hook it up for wirer less printing
You will need to connect an ethernet cable (RJ-45) from this printer to your router, into one of the availlable ports. The router will automatically assign an IP address to the printer.
Then all you need to do is install the software installation CD that came with it on all the computers.
The printer will work wirelessly for all computers you have installed software on, whether they are wired or wireless to the network.
Jun 14, 2010 | Brother MFC-9440CN Laser Printer
How do I connect my Brother MFC-9440CN laser printer to my laptop wirelessly?
You need to supply IP address to your printer then the the Laptop also needs an IP. Try to ping first the printer IP add if its visible. thanks.
May 22, 2010 | Brother MFC-9440CN Laser Printer
How do I set Brother 9440 MFC to print using black cartridge only?
You can set the MFC-9440CN to print with the black toner cartridge only through the printer drivers.
If you are using Mac, this needs to be changed before you print or set a preset.
If you are using windows, follow the below steps.
1. Go to Start menu \ Control Panel \ Printers (devices and printers for windows 7)
2. Right click on the MFC-9440CN and select "printing preferences"
3. Under the "basic" tab, you will see "color mode"; simply select "mono"
Thank you,
Mar 28, 2010 | Brother MFC-9440CN Laser Printer
My yellow toner is out and the printer will not print in just black
The MFC-9440CN should be able to work even if one or more of the color cartridges are empty.
here's what you can do to print in black only.
1. Unplug the power to the MFC-9440CN
2. Clear the print queue on your computer so that there are no jobs waiting.
3. Right click on the MFC-9440CN printer icon and select "printing preferences"
4. Select "mono" as the color mode.
5. Turn the power back on for the printer.
Now when you print it will be in black only and it should work even if all 3 colored toner's are empty.
Thanks,
Pat
Mar 26, 2010 | Brother MFC-9440CN Laser Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
721 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
