Hello, Inside the refrigerator in the top left corner is a plastic box that has vent slots. I think what ever is behind the cover starts making sounds like someone knocking on the front door. It does not make the noise continually but only ocassionally. It will knock 15-20 times and stop.
Can you tell me what is behind the plastic cover?
Thank you,
Ed
SOURCE: Noises when starting up
Mine also makes a knocking noise...like someone's at the door (it freaks the dog out every time). The customer support people say it's normal and so far it hasn't died after two years, so I guess it's not a problem.
SOURCE: Fridge making "knocking" noise
Remove the light shield and there should be screws under it. Remove the air tower in the back, it snaps in and there is 2 screws behind that as well to remove the damper housing that sits behind the light. Also not sure what your model is but some models have 2 air ducts that run up each side, they come out after the light shield is removed by sliding foward and then pulling down. After the screws are removed in the upper plate the light assy will snap out and there is 2 quick disconnects on the wires.
SOURCE: knocking noise coming from Whirlpool Gold refrigerator
The compressor is normally mounted in sound-dampening rubber shock mounts and it sounds as if one or more of these have decayed on your fridge.
Accessing the compressor from the back, you might try (gently) to rock the compressor to see if you can duplicate the noise you are hearing.
Mine does it too. I know what it is because I repair them for a living. That is the sound of ice expanding as the defrost heater comes on to melt the frost on the evaporator. The next ime you hear it make a note of the time. Every 8 to 10 hours it will go into defrost mode. The ice box will also quit working for 21 minutes.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
