Question about Compaq Hewlett Packard Presario SR5110NX PC Desktop
How do I replace a power supply on a Compaq Presario SR5110NX Desktop PC
Posted by bac115 on
Anthony Pierce
    New Friend:
  • 49 Answers
You can purchase a power supply from any computer store *********** board supports both standard IDE and Serial ATA connections, so you want a power supply that does SATA power as well. Unplug the power cord from the back of the computer. remove the cover from the case and verify that there is no green LED on the board that is lit up (if there is, there is still power on the board). unplug all connections from the current power supply, including all drive power and the large 24pin plug (actually a 4 pin plug that is combined with a 20 pin plug) on the board, then unplug the 4 pin plug near the processor. careful that the 24 pin plug and the additional 4 pin plug near the processor have latches on the side. Remove the 4 screws that hold the power supply in and remove the power supply, install new supply and reinstall the 4 screws. first plug in the 4 pin plug that connects with the 20 pin, the 4 pin plug has no latch, it is held in place by the 20 pin plug. then plug in the 20 pin plug and the 4 pin next to the processor. then plug in the drive power to all of the drives. Install the power plug at the back of the system and you should see a green LED on the board when you insert the power. replace the cover and power the system up.
Posted on Apr 03, 2010
Case fan not working sr5110nx
Some fans will not engage if the case is open, others need to be activated in bios (set temp). Also check if the wires are reversed. Some have a diode that only works with current in one direction. Very few use an ac current.
Dec 17, 2013 | Compaq Hewlett Packard Presario SR5110NX ...
Wiring diagram compaq presario hp h10025 product
you wont find one... and not sure why you need one.... if your changing the case then trail and error wont hurt anything
Oct 03, 2013 | Compaq Presario Desktop PC
Lightscribe
Hello Friend,
Some PC also noise like, SMPS fan, CPU fan, external cabinet connect fan. If this types of noise create then you clean all fan dust i think problem solved. You know CUP also create noise it`s default so not any solution.
Aug 22, 2013 | Compaq Hewlett Packard Presario SR5110NX ...
Green power light doesn't turn on but the yellow light goes on
In your added problem along with more information now, you have witnessed what I have previously stated;
http://www.fixya.com/support/t11034057-compaq_presario_sr5110nx_will_not_start
Bad Power Supply.
Weak voltage power rail.
Not enough power to turn the Processor on.
1) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical processor can use from 51 to 125 Watts of power. Just depends on what Processor it is.
(CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short )
The Processor in a Compaq Presario SR5110NX Desktop PC is an
HP Support > Compaq Presario SR5110NX Desktop PC > Product information > Product specifications > Compaq Presario SR5110NX Desktop PC Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01050244&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3436819
Processor - (AMD) Athlon 64 3500+
Socket 939 processor socket,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22ClawHammer.22_.28C0_.26_CG.2C_130_nm.29
Depending on what Core it is based on, (ClawHammer, Newcastle, Winchester, Venice, Manchester, etc), it can use up to 67 Watts, or 89 Watts.
No Processor operating, No computer.
Replace the Power Supply.
{ Also clean out the inside of the computer with a can of compressed air for computers, on a regular basis as needed. It may be every two weeks, if the situation calls for it.
Remember to follow Anti-Static Precautions, BEFORE reaching inside the computer.
N-E-V-E-R use a vacuum cleaner to clean a computer.
A vacuum cleaner produces Static electricity.
{Hold the plastic wand device sideways, over your hair with the vacuum turned on. Your hair will stand up from the Static.
Have seen many a so-called computer tech fry a unit using a vacuum }
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 25, 2011 | Compaq Computers & Internet
Does the compaq presario sr5110nx have an sd slot?
Hi.
In HP support the Compaq presario SR5110nx no SD slot.
Click this product specifications review http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01050244&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&product=3436819&key=null
If you need SD slot try to purchase external USB type universal SD all in one slot.
Hope can help you.
Regards
Jun 28, 2011 | HP Compaq Presario SR5110NX Refurbished...
Windows open so slowly and BellAliant virus scans slow it down even more??
clear all 3rd party startup items you dont need with msconfig.exe. Uninstall bellaliant and use microsoft security essentials as main antivirus software and defragment your hard drive.
Dec 21, 2010 | Compaq Hewlett Packard Presario SR5110NX ...
Compaq Presario SR1265CL replacement power supply
You can replace power supply the higher wattage the better.
Mar 21, 2010 | HP Compaq Presario SR1265CL-B...
Need owner manual to burn DVD
just download imgburn which is a free software to burn dvd's etc. Google "imgburn" and follow the appropriate links to download. Its easy to use by the way.
May 26, 2009 | Compaq Hewlett Packard Presario SR5110NX ...
Compaq Hewlett Packard Presario SR5110NX  PC Desktop Logo
174 people viewed this question
Top Compaq Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
