SOURCE: washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
SOURCE: Overloaded washer, smelled burning. Washer works
On this machine, you most likely just burned the drive belt. The old dependable care transmission design was pretty hard to kill, so just get yourself a new set of drive belts. Very easy to replace/install. You can just tip the machine back to access them. There is a lip on the bottom of the front panel that will hide the pump belt but enough room above it to unwind it off the pulleys. If you want, the front panel can be removed, early models used two phillips head screws to hold the front on or later versions used two clips on the bottom that you can release with a putty knife. Pull the bottom of the front panel forward to un-clip the top and away you go.
SOURCE: kenmore TL washer doesn't spin at end of cycle, burn rubber smell
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*%^%%$$#
have u been overloading this washer?
