Question about Fisher and Paykel DS605I Built-in Dishwasher
Dishdrawer wont empty or fill, makes a whirring sound..
  • Anonymous Apr 12, 2010
    Is has water in the basin and won't drain...
  • luisa_sgro May 11, 2010
    is it full of water or empty? please reply, could b blocked drain
luisa_sgro
  • Fisher and P... Master
  • 713 Answers
Sorry it took me so long to respond but my computer was faulty. now to fix this problem u must first check the drain hose .look under the sink and u will see the small black drain hose connected to the sink pipe. it will have a clip holding it to the spout. remove clip and then remove hose. put end of drain hose into a bucket and turn unit on to a cycle. it should start draining into the bucket straight away. if it does drain into bucket turn machine off and check hole inside the spout of the sink pipe for blockages. if it is blocked clean it out with a small screwdriver and replace hose and clip. if it doesnt drain please reply and i will take u step by step to unblock pump.
Posted on Apr 15, 2010
Testimonial: "Many thanks, that did the job.Some debris in the pipe.. Thank you again"
I have a Neff Dishwasher S5446x0/29 FD 8109 460056. It started making a whirring noise and when I looked it was not emptying the soapy wash water. I stopped the machine and manually drained the water out....
if the pump is not emptying properly it will think its still full, they have a sensor in the bottom that tell the machine that the system is empty and to begin next cycle.
Jun 27, 2017 | Neff 24 in. S5456 Built-in Dishwasher
Hoover 800EL Top loader will fill and empty but will not spin? Making a whirring noise like it is trying to?
Try replacing the large capacetor. This is called apon to give the motor the kick it needs to go into spin. For reference I include a picture to help you locate it.sparkyuiop.jpg
Apr 06, 2011 | Washing Machines
My 500gb wd "my book" is making weird noises and wont show up
The whirring noise is the heads trying to read hard drive and then the weird rubbing screech sound and not showing up in your pc. sounds like the drive is dead.
Jul 14, 2010 | Western Digital My Book Essential 500GB...
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
When ignition is switched on their is a whirring sound and engine wont turn over.and start.
It sound like the lobes on the starter's shaft have worn down and aren't making positive contact with the flywheel anymore. A "whirring sound" would be the starter motor spinning but not "catching". If it's a clicky/buzzing sound then it would more likely be the starter solenoid, low battery/bad alternator.
The "whirring" sound should still be winding down for just a second after you turn the key off. The "buzzing" symptom will stop instantly when you turn the key off.
Dec 02, 2009 | 2002 Jaguar X-Type
Loud whirring noise at start-up
The first thing to check would be to make sure the power steering reservoir is not running near empty, locate the filler cap for the power steering pump it should be marked and then add the appropriate amount making sure you don't over fill, that may make the sound go away if not we must move on to the next possibility, by the way if the noise gets louder when you turn the steering wheel it is most likely the power steering pump or fluid level is low.
Jul 14, 2009 | 1998 Mitsubishi Galant
F & P Dishdrawer DD6031
The Problem is Related to the Dishdrawers Motherboard Control Center This usually happens when water condensation sits on the board to long and Short Circuits controls.
Jul 11, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Whirring sound after long drives 2006 Chrysler Town & Country
It is your power steering pump. The solution is to replace the P/S fluid resevoir and fill or flush the system.
Mar 07, 2009 | 2006 Chrysler Town & Country
Possible pump blocked
dishes have white film glasses are foggy
Jan 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DS605I Built-in Dishwasher Logo
349 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
