Question about True 19 cu. ft. / 538 liter Commercial Freezer T-19F
Freezer begun tripping our 20 amp breaker for some reason
We use this freezer in our concession trailer. We started our season last week. The Freezer ran great. On Wednesday it tripped the breaker. It was running fine all day. It hadn't been opened for maybe an hour or so. We were cleaning up and noticed the interior light was off. First time this ever happened.
Got the rig home, plugged into power and everything ran fine. Didn't Checked again until today - Saturday and found the breaker tripped leaving the freezer at 46 degrees. What would cause this out of the blue?
We purchased this freezer new, 14 months ago and only run it for about 3 months of the year. So basically the freezer has about 6 months of use on it. Any advice?
Posted by wlhcooks4u on
Anonymous
    Novelist:
  • 185 Answers
Ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Posted on Apr 04, 2010
Freezer trips breaker
Try turning the temp control to off. Plug the freezer in for an hour and then turn the temp control down to start the cooling.
Dec 30, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
My FFA70 fridge/freezer is causing my circuit breaker to trip, when I reset the circuit breaker the fridge/freezer will work again, but both the red bight temp warning light and the freezer defrost light...
kevinmdoyle... Hello and welcome to FIXYA,
Yours is a UK model... so I (usa) can't help you
on SPARES (motor start capacitor) ... however
Circuit breakers do go bad...!!
(easiest & cheapest to check first)
MUCH Easier to test the idea than you would imagine:
- Shut OFF your main breaker.
- Open your panel & swap the wire with an EQUAL breaker
- Tag the wires (to restore when finished trouble shooting)
- Restore the main breaker (wait & see)...
and don't forget to clean that CONDENSOR
per owner manual instructions.
If the failure persists... RESORE the BREAKERS.
and
HOPE it is the START CAPACITOR on your compressor.
Carnac the Magnificent
Jan 15, 2018 | Hotpoint Freezers
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Increase 15amp to 20amp breaker?
Hello
Take a look at the model number plate,somewhere the amps should be listed.
Add up the total for both freezers.One may be 8 amps the other 10.
So a 20 amp will work.Do not be more then 10 % over the total.
Jun 06, 2010 | GE Freezers
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
Once in awhile, Circuit Breaker Trips
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Apr 22, 2009 | Frigidaire Freezers
True 19 cu. ft. / 538 liter Commercial Freezer T-19F Logo
351 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a True Freezer Expert? Answer questions, earn points and help others
