Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John Deere x520 pto issue
I have a 4 year old John Deere x520 lawn tractor with 219 hours of use (90% of that time is cutting grass on 3 acre lot). After I removed my snow blade and put the cutting deck back on, I pulled up the PTO swich to engage the blades and nothing happened. I checked the fuses and all looked good. I pulled the cutting deck off to look underneath to make sure no wires were damaged. I cleaned the electrical plugs to remove dirt. My last trouble shooting check before I spend money to have it picked up and looked at by a local John Deere repair shop, is to replace the PTO swich itself to see if that is the issue. Don't think it will be it because I have not used the tractor that many hours and did not have any trouble with the PTO switch last year. Any suggestions before I send it off?
Posted by lkcyford on
Anonymous
    Champion:
  • 235 Answers
Not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Posted on Apr 11, 2010
John deere la105
Grass is too thick & tall and may require a second pass until next time when it'll be easier to cut, or... blades are dull & need resharpening, or... tractor speed too high for the length of the grass.
Jul 31, 2014 | Briggs & Stratton Garden
Why
On 90 psi remove plug, Spray WD40 in cylinder, this will increase the compression for a short time and lube cylinder. Before doing this with both plugs removed try to start engine 3 times to let compression stroke blow out both cylinders. Then spay the wd40. Ensure the oil ha been changed this year!
Jun 15, 2014 | John Deere 23HP VTwin Dual Hydrostatic 54"...
John deere x475 mower will not engage after cutting heavy grass
It is probably full of grass in the mower deck. Clean it out and try again.
Sep 25, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
My john deere z840a keeps overheating. regardless of the grass height and mowing at the proper speed; the temp alarm will come on after about 2 hours of cutting. it has plenty of water/coolant mix and the...
you may want to try heavily washing the radiator with high pressure water from all angles. Over time grass and dirt gets in there and causes overheating.
May 04, 2011 | John Deere Garden
"I have a 3 year old 19"self propelled john dere mower and have had to replace the needle bearings on the drive and told they had rusted due to me washing the mower down (*********) I have never in my 60...
You are one of the unfortunate ones who purchased the John Deere BRANDED push mower.Deere's upper managment decided to use a lesser quality mower made by someone else and slap their logos on it,all to save some $.In all my years with Deere I have never seen so many pushers come back for warranty work.Look on the net and you will find your exact mower a different color for 40% less.
Sep 06, 2010 | John Deere 420,1020,2010,2020,2510,2520...
The riding mower does not mow small strips in the middle of the row being cut. It almost looks like a bad haircut? This happens when I am going fast or slow. It is not a mulcher. This problem is...
Sounds like it is time to replace your blades, I have 2 scotts mowers made by john deere both machines are 9 years old I mow comercially and get 4 to 5 sharpenings the they need replacing.
Oct 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,066 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
