Hi Friend,
welcome to fixya....
This happens sometimes, usually when you stuff too many towels or clothes in the machine. Next time it happens, open the machine, and rearrange the clothes/towels with your hands.
Then turn the machine back on and start it where it left off, not simply popping the button back on, but turning it all around through a cycle and setting the button where you left it on 'rinse'. If it doesn't work simply by rearranging the clothes, pull out one or two wet towels and try again.
If it is due to over stuffing, the rinse cycle should drain and go into spin normally. If this doesn't work then call a maintenance person. It would be awful to have spent money only to find out from the maintenance man that it was an over stuffed machine the whole time;)
if you think that i helped you please rate it\\\\\\\\
thank u...
Hello friend, thanks for your post!
I understand that your Electrolux washer is not draining properly. Some possibilities for your washer not draining could be an issue with the drain pump or control panel. You should additionally check the drain hose to make sure there are no restrictions. If your washer continues to not drain properly you should seek assistance from a professional to repair the appliance. I hope this is helpful. -Matt
