Magellan RoadMate 700 GPS Receiver Logo
Posted on Apr 03, 2010
GPS turns on and goes to warning screen and freezes.
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Apr 03, 2010
Anonymous
Contributor
Level 1:
Answers
23
Questions
Helped
5927
Points
42
You can send your unit in to Magellangps.com or autonav2000.com to recover your MRM 700 unit.
This is a software issue that will require the unit to be reloaded.
Good luck
Magellan roadmate 3055 stuck on warning screen..... shows the check being pushed but then freezes
Called tech support as I had the same issue. Slide the power button over (to turn off). Hold for about 15 seconds. Wait a few minutes after u release the button and then restart. It should be ok after that
Sep 01, 2011 • GPS
Tom-tom screen "frozen" on choosing
These units are prone to freezing on occasion. There likely isn't anything wrong with the unit, just a certain set of particular circumstances caused the software to lock up. Turn it off completely let it sit for a minute and restart it.
If you continually have this problem in the same menu, doing the same thing, I'd recommend updating or reinstalling the software onto the gps unit by following the directions that come with it.
Mar 03, 2011 • Tomtom GPS
I have the Nuvi 255w. when pluged in it turns on and gets to the warning do not attempt to enter route information or adjust this device while driving. then just stays there and the screen freezes. with...
What happens after that screen is that the operating system is loading, I would say that the software is corrupt. Garmin will be able to walk you through reloading the software.
As soon as i turn on my gps it starts to boot up
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, or freezing and rebooting, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
2answers
My Garmin sometimes freezes
Try update the unit with the latest firmware by using WebUpdater from Garmin.
20helpful
2answers
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
1helpful
GPS Does not work
If you have a memory card inserted, remove it...if the problem goes away, try replacing that card. If the problem occurs with any card then...
Try installing the latest update from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
even if you already had the latest...try installing it again.
If the problem occurs with any card, and after updating or attempting to update, there is a probably a malfunction with the XOG and it will need to be repaired/replaced. The Lowrance contact by phone is 800-324-1356 and go to http://www.lowrance.com/en/Support/Product-Support/Contact/ to email them.
Screen Freezes
register your unit on the magellan website and there is a firmware update and it will solve your problem
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
