Question about Denon AVR-883 Receiver
Denon AVR 883 no sound from any source including zone 2 speakers
I have had a Denon AVR 883 for about 8 years, all of a sudden I intermittently get no sound from any source. Sometimes turning it off then back on brings it back.. Sometimes it will come back on by itself while the unit is on. power on cycle seems to be normal i am getting the power relay click and the speaker circuit click. Any one have any suggestions.
Posted by johnlib66 on
Jeff Bonvallet
    Scholar:
  • 41 Answers
This sounds like a thermal issue, meaning after the receiver has been on for a while it gets to warm and then fails. I suspect after 8 years the unit may have accumulated some dust that is not allowing the heat sinks to dissipate heat adequately. I would use compressed air and blow the unit out. Some computer stores have blow stuff in a can that work well. If you have and air compressor, dial it back to 10 psi or so. You will be amazed at how much dust will come out of that unit so you may want to unhook the unit and take it outside. Also be careful not to stack anything on top of your receiver. Make sure there are lots of openings around the unit. High temperatures kill electronics.
Hope this helps.
Posted on Apr 03, 2010
No sound from new sony bravia to denon avr 1610
TV's are not your best source of audio. Get the TV-related audio digitally from the source, NOT the TV.
Jun 25, 2010 | Denon AVR-3300 Receiver
No sound when on internet radio, playtime is running, volume is not muted, internet ok
It was solved by turning the receiver off with the power button (not stand-by). After turning on the netradio did have its sound back. Apparantly it must be running some sort of Windows os.
May 16, 2009 | Denon AVR 3808Ci Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
No sound coming out from ANY speaker
muting is on switch off muting.
---volume control is in low level------turn volume up.
------input signal of audio source not selected------select your audio source.
Jul 29, 2008 | Denon AVR-2802
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
Mar 26, 2008 | Denon AVR-883 Receiver
Denon AVR-1803 shuts down
I am a Tech in Michigan and have worked on lots and Lots of Denon AV Receivers. These units have Protection circuits for Overcurrent, Dc Protect, 15v Regulator inbalance, Rail Voltage Inbalance, Low Ac Voltage, Low Standby Voltage and Thermal Protection just to name the ones I remember. My guess is you Probably have either Poor Intermittent solder connections or Amp is not Ventillating Properly. Make sure you leave room above Receiver to Vent and You are using no Less then 6 ohm speaker Impedance per ch. Refer to Speaker Impedance chart on back panel . [email protected]
Dec 06, 2007 | Denon AVR-1803 Receiver
Intermittent audio output
It's quite possible one of the relays is failing that is part of the switch between audio output choices.  Do you notice any output difference between a certain output (i.e. dvd, tape etc)or is that point arbitrary?
Sep 10, 2007 | Denon AVR-3300 Receiver
Denon 2902 No Sound
REPLACE MUTING TRANSISTORS IN DSP PANEL
Sep 04, 2007 | Denon AVR-2802
Denon AVR-883 Receiver Logo
140 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
