Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Garbage Disposal has a humming noise. Motor is turning ok. Just not going down sink?
Posted by craig_scott3 on
DAVID CAYCEDO
    New Friend:
  • 94 Answers
Sound's like you have a blockage in your drain pipe's. take apart and, while you have it apart check the fitting right at the disposal
Posted on Apr 29, 2010
tip
Garbage Disposal Leak from bottom of motor
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
My garbage disposal is not working. it "hums", but doesn't grind, and water drains slowly. there is nothing stuck in it.
You are going to have to try to push it through the stuck point. It is clogged without a doubt. Could be a piece of silverware in there. Use a flashlight and take a look down in the hole. Do not stick your hand in there but you can use a pliers or something to dislodge it.
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2helpful
My garbage disposal will not start from a dead stop.
The motor start winding has gone bad, or capacitor burned out.
Generally disposals are replaced when motor goes bad.
Mostly because the disposal is sealed unit and cannot be easily disassembled.
If you have local motor-repair guy, who has disposal bearing parts, and can get the disposal apart, then repair might be possible... but the bearing seal would be hard to replace.
Copy following link for replacing garbage disposal with tips from when I did apartment maintenance.
When turning on garbage disposal power turns on but does not spin
Is the motor rotating, and cutter disc stationary?
If the motor is running but cutter disc is not moving, then disposal is probably broken and needs replacement.
If the motor is not rotating, and is making humming sound, then do not keep power turned ON or motor will burn out.
Then use allan wrench on bottom of disposal to rotate the motor until disc rotates freely. Also use wood broomstick handle down into disposal and wedge against side of sink opening to free cutter disc.
Also view ez disposal replacement steps:
http://www1.fixya.com/support/r7929008-replace_garbage_disposal
I think I ground up a plastic bag in disposal....I have cleared out as best I can, turned the blades with a wrench, re set the button, but it won't move, just humming....does the unit need to be...
Don't keep running the disposal when it is humming or motor will burn up.
You might need a plumber, and/or might need to replace disposal.
1) If the disposal cutter disc turns freely, and motor will not start then disposal has gone bad.
2) If disposal cutter disc is still stuck, then you might be able to salvage by removing two nuts on p-trap below sink.
P-trap drops free.
Remove 2 bolts holding tailpiece to side of disposal so you have access to plastic bag from below the cutter disc.
Keep removing plastic bag and keep working the wrench from below. It should eventually give way.
Put wood broomstick down sink opening and wedge broomstick against sink opening to get cutter disc to rotate.
Spray WD40 into opening to help lubricate the struck parts.
3) I wrote ez disposal replacement steps that also cover tips for reassembling p-trap.
3helpful
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sink garbage disposal not working! when I switch the garbage disposal on, nothing happens!
Do you hear a humming sound when you turn it on? If so, you have a clogged disposal. Check on the bottom for the allen wrench location recessed in the middle of the disposal. Insert the proper size allen wrench and you'll be able to rotate the motor back and forth (sometimes difficult at first) and eventually loosen the clog and free up the motor. If you're able to move the shaft/motor easily in the beginning and it still doesn't work you may have a defective disposal. If you want to check more thoroughly you'll need to check to see if you have power at the disposal when you turn on the switch. Use a electrical tester that you can buy at any home improvement store to see if you have power at the disposal. If so, and the motor turns easily when you use your allen wrench, you have a defective disposal and it needs replacement.
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
Top Ace Hardware Electrical Supplies Experts
Mike
Michael Schaffter
Michael Schaffter
Level 1 Expert
durantheman
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
