Question about Gateway MX6214 Notebook
How do I access the hidden partition to reinstall operating system?
Posted by jtedesco59 on
Anonymous
  • 749 Answers
Turn on or restart your notebook, then press F11 while your notebook is
starting.
3 Insert the Operating System Recovery CD/DVD when prompted. The System
Recovery program starts.
Click a system recovery option
Full System Restore (Destructive) reformats the hard drive and
restores the system software as it was when you purchased your
notebook. This process deletes your data files.
Full System Restore with Backup (recommended) moves the
contents of the hard drive to the C:\My Backup folder and installs
a new copy of Windows XP. This option saves your existing data
files, but all programs must be reinstalled and the program settings
reconfigured. You need at least 4 GB of hard drive space to use this
restore option.
5 Click Next. The System Restore - Format and Recover dialog box opens.
6 Click Yes. Files are restored to your hard drive. When file recovery has
finished, the System Restore dialog box opens.
7 Click Restart. Your notebook restarts, and Windows finishes its setup and
installation.
Important
After you restore your system, it will
appear with the same files and programs
it had when it shipped from the factory.
You still need to download Windows
updates and antivirus updates to bring
your notebook’s software up to date.
8 Reconnect your Internet cable and all USB peripheral devices. You are
done.
Posted on Apr 03, 2010
Operating guide
is your hard-drive the boot-drive, if not, change boot order by pressing F8 or F12 just after hitting the start button, and choose the hard-drive that has the C:\windows on it.
or hit F11 and access hidden recovery partition with HP pavilion How to Access the Hidden Recovery Partition in HP Pavilion
Mar 23, 2014 | HP Pavilion Computers & Internet
How do I get to the hidden recovery partitio on dell inspiron 1018 10monts old
Hi.
You can access your Dell's recovery partition by pressing Ctrl+F11 when the machine is first turned on. The appropriate time to do this is almost immediately after the power button is pressed.
Regards.
Jun 17, 2011 | Computers & Internet
How do i reset my acer laptop back to factory settings
What Acer model do you have? Are you running Win7? Most Acer notebooks have a hidden partition on the C: drive where the operating system is located. The following information can be found at the Acer support website:
http://acer.custhelp.com/app/answers/detail/a_id/2631 :
How do I reinstall the Operating System on my computer?
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form.
Hope this works for you. Please rate this answer if it was helpful. Thanks.
Apr 15, 2011 | Acer Computers & Internet
Not recovery for Vista after installed Windows XP. Not repair file recovery.
The Computer is shipped with the Recovery Center, a hidden partition in the Hard Drive. Please restart the Computer and press the F10 key when the VAIO logo appears to access the Recovery Center.
If the Recovery Center is accessible, select Restore C Drive to reinstall the pre-installed Operating System, Applications and the Drivers (restore to factory settings).
If the Recovery Center is not accessible, then the Recovery partition may be deleted. In that case, you can contact Sony Accessories and Parts Center from US at: 1-800-488-SONY (7669)to order the Recovery Discs.
Good Luck!
Thank you for contacting.
Jul 03, 2010 | Sony VAIO VGN-CR515E/B Notebook
Reloaded xp pro on dell lap and then the blue screen of death and now nothing except error loading os Please if you can help I know very little about computers so bear with me...
Just about every prebuilt system. Dell, HP, Compaq, e-Machine ECT.
Place a small hidden partition at the front of the primary hard disk drive.
This partition is about 2MB to 4MB in size. Within this hidden partition are drivers. If you need to reinstall your operating system you will need to use the manufactures restore CD's. On the other hand if you are trying to install another operating system like, (An upgrade or a full install of another OS), though it may appear windows is installing it is not. Hence the blue screen. Once you delete this hidden partition you can install or reinstall the operating system of your choice. There are two ways around this. 1.) Download and run a program called, Darik's Boot and Nuke for CD and DVD 1.07. This allows you to create a bootable CD or bootable floppy disk. Download link below;
http://download.cnet.com/Darik-s-Boot-and-Nuke-for-CD-and-DVD/3000-2094_4-10151762.html
This program will remove/delete everything including hidden partitions.
This program has been updated so you can remove the hidden partition without harming your current windows.
Once completed you will be free to install any operating system.
2.) Run Darik's Boot and Nuke to remove the small hiddion partiton.
Boot to your windows CD. Carefully read the screens that come up. If you have personal data in your operating system and don't want to loose that data than follow these instruction. During the install of windows, you will come to a screen where windows will show you the partitions on your drive. If your drive has a min of 50 to 60GB of free space you can create another partition within the free space and install windows fresh. Once windowsw has been installed and updated you can now copy and past all your personal data to the new windows.
When finished, click Sart, Run and type " diskmgmt.msc " and click ok. In windows disk managment you can now delete your old windows partition. If you need help using diskmgmt.msc just open the link below;
How to use Disk Management to configure basic disks in Windows XP.
http://support.microsoft.com/kb/309000
IHope you find this helpful!
Mike
Nov 23, 2009 | Dell Computers & Internet
How do you restore the laptop with the internal restore system
1. According to the specifications available online, your Computer is shipped with the VAIO Recovery Center software, present in a hidden partition. You can use the VAIO Recovery Center to install the preinstalled Operating System, Applications and the original Drivers.
2. Restart the Computer and press the F10 key when the Sony logo appears to check whether the Computer is able to access the VAIO Recovery Center.
NOTE: Restart the System, tapping the F10 key immediately. This should trigger the System to boot directly to the Recovery Partition, and initiate the VAIO Recovery Center, without requiring the Windows Operating System to load.
3. If you're able to access the VAIO Recovery Center, select the option 'Restore C: Drive' and follow the onscreen instructions to perform a C: Drive Recovery to resolve the issue.
4. Performing a C: Drive Recovery will erase all the data present in the C: Drive and will reinstall the pre-installed Operating System, Applications and the original Drivers.
For further information you may refer this link also:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C459775
Good Luck!!!!!!!!
Oct 07, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Need to reinstall LGX11 (model X110)
The best option would be to connect the hard disk to another computer which has an optical drive, load the OS into it and return it back to its native PC. Or as you asked, you can check for other solutions too
http://boshdirect.com/blogs/tech/os-install-without-cd-rom-support.html
Sep 05, 2009 | Computers & Internet
Acer t650 usb problem,add hardware wizard starts whenever i plug in a usb device. factory drivers not helping. xp home o.s.
hello, the usb driver is missing from the system you will need to provide the driver that came along with your system.
Apr 04, 2009 | Acer Aspire T650 (AST650UC3601) PC Desktop
Problem with hard disk partition
there is a default and a hidden partition on it.. consist of all the back-up drivers for the laptop.. i recommend you go to the lenovo site and search on how to access the hidden partition..
Sep 23, 2008 | Lenovo 3000 Y410 Notebook
Gateway MX6214 Notebook Logo
513 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
