Question about Hitachi 53SWX10B 53" Rear Projection Television
Hi, I have a Hitachi 53swx10b projection tv. the colors are bleeding and sort of glowing. any idea what this tv needs? thx, John
  • Hitachi Master
  • 8,457 Answers
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
Posted on Apr 03, 2010
    New Friend:
I have a hitachi 53swx10b  and need the green lens and whole assembly? Any one know what it's called?
Posted on Mar 30, 2011
6ya staff
SOURCE:
I HAVE A HITACHI 53WX10B TV AND THE SCREEN IS BLURRED. I HAVE TRIED THE MAGIC FOCUS BUTTON AND THE SHARPNESS BUTTON. ANY OTHER IDEAS?
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
Dec 04, 2010 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 62 v569a has a blue gost line around the sides i replaced the bulb and didn't seem to help can u give me a idea what might be wrong thx
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to solved tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 17, 2010 | Hitachi 62VS69 62" HDTV
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Color on Panasonic 2004 is off and appears to be warped
It sounds like a convergence problem; most of these sets use two convergence IC chips that both need to be replaced; usually this can be done right in your home.
Aug 16, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi projection hdtv has 3d effect and bowed shape
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2009 | Hitachi 53SWX01W 53" Rear Projection...
Hitachi 53SWX10B has picture but no sound
Hi, not good news, you have a bad surround module and this is a VERY difficult repair job, most techs send it to PTS and then they don`t get it right about 10% of the time either, Have a tech pull the board and send it out theres nothing you can do to repair it, sorry for the bad news, video-tek
Jan 30, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Wavy lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 53swx10b 53 in. rear projection
best to bring in a find a ISF tech to do the calibrating of the set, when you call in for repair make sure he's ISF
Oct 22, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 53swx10b
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Mar 30, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 53SWX10B 53" Rear Projection Television Logo
197 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
