Acer Aspire One A150-1006 Notebook Logo
Posted on Apr 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot play dvd movie at media player 12 - Acer Aspire One A150-1006 Notebook
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Apr 03, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557491
Points
31058
What happens?
What does not happen?
What do you expect to happen?
What error-message(s) do you get?
Does the DVD-movie play in some other DVD-player or some other computer?
1helpful
2answers
Why is it that sometimes I can watch DVDs on Windows Media Player and sometimes not?
Some movies are encoded with a protection the Disc acts as if you are tempting to copy the write protected dvd. you can get a program for free called shrink dvd that will remove the protection and copy the movie to your Pc so you can watch it.
6answers
Can not play vod file on computer oops , I meant VOB files on my DVD movie, or why did MS media player fail, as all do.(OOBE)
I assume you mean VOB. I have not heard of a VOD file...
If you have gotten your hands on a VOB file somehow, chances are they have been copied/extracted from a DVD. VOB stands for DVD Video Object and is the core file of a DVD containing the actual movie data, an MPEG movie stream and the supported audio.
To play the VOB files, you need to have a DVD player that supports VOB format. However, if you have the Windows Media Player (version 12 or higher) or VLC Media Player, it is good enough to play the file. Note that you will see a prompt telling you that it is an unsupported format, don't worry about it and just play it anyways. It will play just fine.
If you want to obtain the VOB file from a DVD for some reason, just open the DVD in Windows Explorer instead of playing it through a media player. The VOB file would most likely be under the VIDEO_TS folder. Some other files that you will also see in the folder are IFO and BUP. The IFO files are the information files containing meta data about the DVD and instructions for the DVD player on how to handle the disc. The BUP file is simply a backup copy of IFO files.
If you want to convert VOB file to AVI or a similar format, aviNET is a great tool to do that
3helpful
5answers
I have a Dell Inspiron E1705 Notebook running WindowsXP with a DVD-RW/CD-RW drive. When I insert a DVD to play or to copy it won't work, it tells me I need a DVD decoder. How can I get one to solve this...
Just download FFDShow and VLC MEDIA PLAYER.
Its extremely rare with this combination, to find a movie that wouldn't play,
get FFDShow here http://www.free-codecs.com/download_soft.php?d=5550&s=50
with ffdshow all you need to do is to run the setup file and click next repeatedly untill the setup is complete, and then just finish it, close it and its done, works on the background when movies are played.
vlc media player - http://www.videolan.org/vlc/
After you got these two installed, you should be able to play most if not all of the movies out there.
open vlc media player and then click File, dvd movie.
3answers
Cannot play DVD, cd video wont play to media player
not sure whether its a problem with the drive or a problem with windows media player. Take a can of air and blow some onto the laser of the dvd drive, this will make sure that there is no dirt or dust on the laser.
Once you do that put the dvd back into the drive. Give it about 20-30 seconds and then see if it tries to pull up the movie if it does and your getting errors from windows media player then we know that the drive is working cause its seeing the movie properly.
At that point, I would suggest downloading the latest version of windows media player.
Go here to download the latest version of Windows Media Player 11.
After doing that and installing it, try playing your movie again, in fact try several movies just to make sure. Windows Media player may want to download Codecs, if it does then let it. This will allow it to recognize dvds better and quicker.
If the codecs are updated and you still can't get it to see and play movies then I would suggest using a different dvd player such as Cyberlink PowerDVD located on this page:
http://download.cnet.com/windows/dvd-software/
Just purchased an acer aspire one, can get movie from external dvd play playback on media player & power dvd 8 but not sound. sound plays on cds & everything else, plays on movies downloaded online...
AVS DVD Player is a free universal player that I put on all Acer Ones that I sell. It is an excellent player, that can go full screen and handle every format. It will even play VOB files which are dvd files "ripped" from dvd discs. I have never had a failure with this program....
http://www.brothersoft.com/avs-dvd-player-free-44678.html
4answers
How to make dvd in computer for playing it in a
To copy from dvd you will need to RIP the movie in media player
Then you will need to burn it in burn list in media player.
For other movies that are AVI files and you want them on disc to play in DVD player, then you will have to download ConvertX to DVD program and convert file from AVI to DVD
2helpful
5answers
MY WINDOWS MEDIA PLAYER CANNOT PLAY mpeg 4 MOVIES
you can go to divx.com and go to free download, this codec usually has codec for movies
3answers
Windows media player doesnt play dvd movies
Simply install a DVD player separately or DVD Codec for Window's Media Player. The reason why Window's Media Player can not play the DVD movies is that it does not has a DVD codec to play it. The simplest solution to do it is to install a DVD Player program and Window's Media Player will start playing DVD movies.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
