Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
The child lock is stuck on my kitchenaid superba dishwasher
Posted by bfdphillips on
electronic & computer repair& servicre
  • KitchenAid Master
  • 12,061 Answers
Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Posted on Apr 03, 2010
  • ojbecker Sep 04, 2010
    Fantastic! I was really in a bind with so many dirty dishes and then this child lock
    indicator would not turn off. Thanks to your advice I am back in the dishwashing
    mode and what a relief!!!! I was expecting to have to call a repair-man over
    and pay dollars!! THANK YOU!!!!
2 Related Answers
Mukesh Kumar
  • 3230 Answers
SOURCE: Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Posted on Mar 02, 2010
Paulo
  • 188 Answers
SOURCE: Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Posted on Feb 18, 2009
My top drawer of kitchenaid dishwasher lock light is on. I can't get it off?
It's a child lock. To turn off the child lock on a Kitchen Aid dishwasher, locate the Energy Saver/Dry button. Press and hold this button for at least four seconds.
Jun 20, 2016 | KitchenAid Dishwashers
How do I shut off the child proof lock on my kitchenaid superba dishwasher? There is a red light blinking and I have no idea how it came on as I did not push anything different than I usually do when I...
Hi
To reset the dishwasher control you have to press and hold the HEATED DRY button for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 16, 2011 | Dishwashers
KITCHENAID DISHWASHER SUPERBA MODEL KUDS01DJSS0 CHILDLOCK DOES NOT OPEN .REMAINS IN LOCKED POSITION EVEN AFTER POWER RESET. CAN'T USE THE DISHWASHER.
The easy solution is to try pressing the Energy Save Dry button & hold it in for 3-5 seconds. This should turn the child lock on & off.
If this doesn't work, then it's likely that one of the pads on the control panel is stuck, and it (the control panel) will have to be replaced.
If you don't have the manual, you can download one here (PDF format). Good luck!
Mar 02, 2011 | Dishwashers
Good Luck!!
Thanks
Mar 02, 2010 | KitchenAid Dishwashers
Door will not open on my KitchenAid Superba dishwasher
Hi Karissa (I LOVE your name!)
I took the opportunity of your post to upload a technical service manual for you. The "child lock" feature is only for the control functions (the buttons) and has nothing to do with the door actually locking. Here is the link to the tech manual. I hope you find it useful.
SG
Apr 16, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Child lock shut off
Feb 18, 2009 | Dishwashers
Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
1,248 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
