Question about Kenmore Elite 44723SS Commercial Refrigerator
I bought a new water filter for our kenmore elite refri. and i cant the filter to stay in, it keeps popping out.
  • 15,935 Answers
Check the oring seal for damage. If it is not in place - the filter will not fit properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have a Kenmore Elite 795.71033 bottom freezer french doors. The freezer is staying at 20 degeres
is the water turned on again ? (to replace the water filter, you had to turn off the water.) also, when you moved it back into place, did you pinch off the flexible water line ?
Sep 12, 2018 | Kenmore Refrigerators
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
We just replaced the water filter cartridge for our Kenmore refrigerator (model # 25352649305). The new cartridge was easy to install but doesn't stay locked in place. As soon as we go to use th
Pull the new cartridge out and check it side by side with the new one. make sure they are identical or that there are no tabs to pull off before install.
Please mark this as helpful if I helped to solve your question.
Dec 14, 2017 | Kenmore Refrigerator Replacement Water...
My Kenmore elite 40512900 stays at 7 minutes
well often when it hits the last ten min of a cycle it is trying to drian more times then not it isnt or it hasnt senced it has drianed so odds are that your drian pump not drianing or you have a bad pressure switch. i would start with the drain pump often it has a filter that get clogged and can be gottin to from the front
Jun 02, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite Smartheat quietpak9 model HE4, keep turn off after 15 to 20 minutes, it does getting hot. Could you please let me know what will be a problem. I bought it used so I am not sure how old is...
might need a clean out keeping heat inside of dryer,or you have abad motor,take the vent line off the back of dryer and run it to see if the block is in the vent line or in the dryer,also take off bottom panel,unplug dryer,take out lint filter and then remove the duct that the filter slides into,if it's blocked clean it out and you should be all set,usually the thermal fuse pops when this happens so that's why i say you could have a bad motor
Dec 15, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER DOOR WILL NOT STAY CLOSED WHEN IN USE
Most likely the receptacle that the door latch goes into is broken. Go to local appliance parts dealer with model number and buy the $5 part, or order through Sears Parts Direct online.
Jun 13, 2009 | Kenmore Elite HE4 Electric Dryer
Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Jun 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 44723SS Commercial Refrigerator Logo
175 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
