Question about Boating
What is the mixing ratio for 9.8 hp mercury the year is in the 80's 100 to 1 50 to 1 30 to 1
Posted by sg_miketarge on
Dean
  • 285 Answers
50:1 is the ratio to go for.
Posted on Apr 02, 2010
I have a 35 hp mercury 2 stroke motor nr. is 7218535 fuel mix is
Older outboard motors usually take 50 to 1 mix ratio where as the newer ones often take 100 to 1 mix ratio.Try Google to double check.
Aug 12, 2018 | Mercury Boating
25hrs 2 stroke mercury what gas mixture.?
Most use a 1:50 ratio, I've seen them as rich as 1:40 while some later outboards use 1:100. What year is the Merc? Mercury's support page has lots of info and Also, here's a handy chart for mixing. https://www.mercurymarine.com/en/us/service-and-support
Jul 12, 2018 | Garden
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
What is ratio per gallon for mercury 150 v6
Hi Daniel!
Oil mix is 50:1 (Quicksilver recommended. Go figure!)
Here's a link to your service manual if you need it.
-Steve
Boatinfo Mercury Service Manual for 135 150 175 200 hp
Sep 09, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Oct 25, 2009 | Boating
Want to know what the gas / oil ratio is on a 1973 4 hp mercury motor. s/n 3657708
The fuel ratio is 50 to 1. Fuel/oil.You can go as low as 40 to 1 fuel/oil.40 to 1 is the richer mix.Hope this helps
Oct 05, 2009 | Boating
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Smoking outboard
Sounds like your running a bit rich. Try leaning down your air/fuel ratio.
Aug 23, 2009 | Sport & Outdoor - Others
Boating Logo
147 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
