Question about Logitech Harmony 550 Remote Control
No responce from a harmony 550 remote
Buttons will not respond when pressed on a harmony 550 remote.
  • 1 more comment
  • Anonymous Apr 04, 2010
    I have actually done all of that and still I get nothing when I press a button.
    Yes, I've had the remote going on 3 years now. Have not touched it (setting and firmware wise) in a year.
  • Anonymous May 11, 2010
    1. Have you programmed the remote?
    2. Did it work before?
    3. Did you make any changes to the settings which caused it to sotp working?
Jeff Bonvallet
    Scholar:
  • 41 Answers
First I would remove the battery for 10 min then replace. If that did not help, I would hook the harmony back up to your computer and update the remote. If that does not fix the problem then I would down load the firmware and then update your remote. Even if your current firmware is up to I would still download and update the firmware.
Hope this helps.
Posted on Apr 03, 2010
  • Jeff Bonvallet
    Jeff Bonvallet Apr 04, 2010
    If you have updated the remote with new firmware and program and the unit is still not working then your unit has likely failed at the circuit board level and is time to purchase a new remote. With nothing to lose at this point, and as a last resort, I would pull the unit apart and look for any contamination on the circuit board. You know coffee, soda, a hamburger...etc. In general you can use alcohol to clean electronics. One other helpful tip is to check and see if the IR led is working. You can use this trick with any IR remote. Using a digital camera point the remote at the camera and press a button one the remote. If the IR led is working then you should see it glow. One last thing, calling customer service at Harmony might get you 50% off your next purchase. I have had one customer who’s remote was out of warranty, and they offered 50% off list price. Good luck I, and I sure hope this helped.
Loigitec Harmony 550 Remote does not respond to buttons pushed
The following steps will reset your remote. If this does not fix it, then it's probable a hjardware related problem.
1- Remove the battery from the Harmony remote, hold the 'Off' button and insert the battery back in. The screen will display 'Safe Mode'.
2- Make sure you have version 7.7.0 of the Harmony software installed on your computer. You can download it at http://logitech.com/myharmony.
3- Launch the software and log in to your account.
4- Click on 'Downloads' at the top of the screen.
5- Click 'Firmware' and follow the steps to update the firmware on the remote.
6- Update your remote.
Jul 21, 2010 | Logitech Harmony 550 Remote Control
Harmony 550 quit responding as I watched a blu-ray movie.
Hi. The 'Welcome to Your Remote' messageon a H550 means that there is a button that is stuck down on the remote.
1. Take out the battery, and push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware. To do this, log in to the software, click 'Downloads' at the top and 'Firmware'
3. Update the remote.
That should get the remote working! :)
Apr 15, 2010 | Logitech Harmony 550 Remote Control
My remote for the harmony 550 says welcome to remote even after I replaced old batteries with brand new batteries. No buttons will work any suggestions?
First I would check to see if any of your buttons are sticking. I have found that this is a common problem with the 550 remote. I really like this remote but if nothing works check your buttons to see if any are pressed under the plastic. This remote can only work one button at a time so if one is being pressed it will not work.
Dec 10, 2009 | Logitech Harmony 550 Remote Control
My logitech 550 is not responding. It has worked
Hi. That message means that there is a button that is stuck down on the remote.
1. Take out the battery, push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware,
That should get the remote working again. :)
Oct 31, 2009 | Logitech Harmony 550 Remote Advanced...
Harmony 550 is locked on safe mode
Try this:
  1. Remove the batteries from your remote
  2. Press and hold down the 2 button while connecting the remote to your computer
  3. The Harmony Remote LCD screen should display Upgrade Success
That should do it. If it doesn't work try pressing all the keys and make sure none are stuck in the down position and then retry the above steps.
Oct 03, 2009 | Logitech Harmony 550 Remote Control
My logitech 550 remotes buttons will not work
Did you try updating the remote through the desktop software? Something might be wrong with the firmware that an update could fix.
Aug 02, 2009 | Logitech Harmony 550 Remote Advanced...
The # 5 button needs to be pressed hard to respond All the rest are fine. It seems to have worn out.
you have solved your own problem! The # 5 button is worn out and that is quite common in all remotes. (not just the # 5 but any button or buttons)
Jul 22, 2009 | Logitech Harmony 550 Remote Control
Remote is frozen. remote says welcome to remote but does not resp
To get your 550 out of safe mode, follow these steps. 1. Remove the batteries. 2. Hold the '2' button down. 3. While still holding the '2' button down, replace the batteries. 4. The remote will boot into the normal functionality. Note: If the 'Off' button is held down while inserting the batteries, the remote will boot into 'Safe Mode'. Also here for manuals: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=logitech
May 02, 2009 | Logitech Harmony 550 Remote Control
Logitech Harmony 550 will not respond.
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Apr 22, 2009 | Logitech Harmony 550 LCD Remote Control
Display shows "Harmony safe mode" and will not respond/turn off
remove one battery. press and hold the #2 while replacing the battery. hold the #2 until you see "upgrade success". press activities and you're back in business.
Mar 07, 2009 | Logitech Harmony 550 Remote Control
Logitech Harmony 550 Remote Control Logo
238 people viewed this question
Top Logitech Televison & Video Experts
Tom Chichester
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
