Question about Boston Acoustics MicroMedia Computer Speakers
I can't get sound out of me speakers. I just had my hard drive rebuilt. the system is a Soundblaster
Posted by jwray284 on
paul7of9
    Genius:
  • 1,189 Answers
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues."
In the See also: (Category), click, on “Audio DevicesI can't get sound out of me speakers. I just had - 2_bing.gif, and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced),“not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. “Did this solution help?”
Posted on Apr 02, 2010
How to disable onboard sound on the ASUS P5QPL-AM Motherboard ? Can't seem to find it in the bios... Installed a soundblaster but there's no sound.
Have you installed the Soundblaster drivers? Have you plugged your speakers in to the soundblaster outputs? When you install a discrete card (graphics or sound) it bypasses the onboard chips. You could also try the audio settings in the control panel.
Sep 22, 2013 | ASUS Computers & Internet
Can i use my boston 5.1 speakers with a powered sub with my new computer system.it used soundblaster software?
The speakers themselves don't care what you have them connected to. They just take an audio input from the computer, which is a function of the computer's sound card and drivers. As long as the computer hardware is working properly, the speakers will too.
There is one possible problem, though. If these speakers came with your computer as part of a Gateway system package several years ago, they may be a digital-input version only. Gateway supplied these speakers and a Creative Soundblaster card that had a digital output was installed in the computer. The way to tell on your speakers is to look at the plug on the end of the cable. Which of the two below looks like yours?
If it's the one on the left, you can use the speakers with any analog sound source (computer, iPod, etc.). But if looks like the one on the right (a mono plug), you have the digital speakers. Unless the sound card in your new computer has digital output available, the speakers won't work. In the past, I was able to put the original sound card and drivers into someone's new computer and it worked, but the original software is not compatible with Vista or Windows 7.
Hope this helps you get it figured out. Thanks for using Fixya!
Dec 02, 2010 | Boston Acoustics BA7500 Computer Speakers
I am currently on Windows 7 Ultimate and I have surround system of Logitech X-530 and the front 2 speakers a playing sond how do I solve this to make the other work as well? Additional information: I also...
Hi...hard time with your logitech Speaker., do you have a 5.1 sound card install inside your pc, like 6 outputs and two input jack on your sound card... a pro sound card to make your logitech X-50 work like a charm if you dont have... I suggest to by a creative soundblaster pro 5.1, but if you do have a surround sound card with 6 input jack install in your pc and fail to work properly...ride down the model of your sound card and check if it compatible with windows 7., just download the patch for it... good luck.
Nov 02, 2010 | Logitech X-530 Computer Speakers
I am running a dual boot system. My Linux can only tolerate the audio system on the mother board. My windows XP is on the advanced sound system which is a Soundblaster Live (WDM) which works fine. But I...
Hi, There are two ways to do the same. One way is : open the computer cover and remove the expansion card( sound card ) from the system and the audio would default to intergrated audio
second way is Click on start>click run> type devmgmt.msc> the device manager window would appear go to the option that says sound audio and game controllers, disable the soundblaster by right clicking on the same.
Thanks for using fixya proton
Nov 11, 2009 | Dell Dimension 4600 PC Desktop
It is possible to connect 4.1 Speaker to Laptop
maybe the type of the sound card on the laptop is not compatible with with the creative speaker system.try to play other speaker systems
Nov 09, 2008 | Creative Labs SoundBlaster Live Dolby...
Driver
there are no drivers for the speakers, you need an audio driver installed for you sound card.
http://support.dell.com
Your system will either have an on-board sound card (Sigmatel normally) or a soundblaster expansion audio card. (If the audio jacks are in an expansion slot below the video card, then you have a soundblaster.
Soundblaster drivers are found at http://www.creative.com
Jul 16, 2008 | Dell 5650 Computer Speakers
X-540 Speakers
go into sound device on control panel. make sure digital is unchecked.
Feb 08, 2008 | Logitech X-540 Computer Speakers
Maya44 poor sound quality
Check the maya graphics card audio settings. there may be some improper audio setup. the Maya 44 card audio codec and filters are not supported by your OS. Your system configuration is good. there may not be any problem with Pc compatibility. only because OS audio codecs. try dowloading codecss for this audio rendering device
Dec 17, 2007 | AudioTrak MAYA44 MKII Sound Card
Boston Acoustics MicroMedia Computer Speakers Logo
140 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
