Lexmark X5470 All-In-One InkJet Printer Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My x5470 shows light on copy mode only and if i try to press some thing else nothing happen
  • Official Brand Answer 3,344 Answers
  • Posted on Apr 02, 2010
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923704
Points
5508
Remove the power supply (black box where the power cord is plugged in behind the printer) with the power cord still plugged in it and other end still plugged in to the power source/outlet. Leave it unplugged for about 10-15 seconds. Then, plugged the power supply back in the printer. Make sure to plug it in the correct position. Hope this helps. If not, place a comment so I can get back on this. Good luck!
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Lexmark X5470 is not printing but the software thinks the printing is complete. What's wrong?
It could be that your cartridges need some cleaning. From the printer operator panel, while on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them from possible clogs and dirt.
If that doesn't help, try to re-seat your cartridges into the printer. You may also replace your cartridge with a different known working cartridge to determine if it's a faulty cartridge issue.
1helpful
THE TIME IS WRONG ON X5470
To change or set the time on your Lexmark X5470 printer, please follow the steps below:
  1. On your printer operator panel, while on Copy mode, press the Menu button.
  2. Use the left/right arrow button, select Tools.
  3. Use the left/right arrow button, select Device Setup.
  4. Use the left/right arrow button, select Date/Time and configure the time.
I hope this information has been helpful.
Message shows out of paper during copy or receiveing a fax
Take it back. It is broken. If It was older I would suggest some things, but it would probably invalidate your warentee
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Faxing problems
Are u using a dedicated line for the fax or is it shared.....
If u are using an answering mech...then u need to set the rings...on the fax greater than the answering mech...
Or else Clear the NVRAM....(Note u will loose all the contacts saved in the fax mech)
a. Make sure the printer is in “Copy Mode”.
b. Press the “Menu” button once.
c. The screen will display “COPY MENU: Copies”.
d. Press the left arrow button once. The screen will display “COPY MENU: Tools”.
e. Press the button once. The screen with read “Tools: Maintenance”.
f. Press the button once. The screen with read “Maintenance: Ink Levels”.
g. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
h. Press the button once.
i. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The printer will prompt u to set it up
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
2answers
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
