Question about HP Color LaserJet 2600n Printer
Sensor error respected sir, i have a 2600n colour laserjet hp printer it show a msg that after initializing "sensor error turn off and on"
Posted by sarunkottuva on
Walid M Sayed
    Sergeant:
  • 313 Answers
Sir
contact me at [email protected] and I will send you the service manual for free
regards
Posted on Apr 02, 2010
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Hp laserjet 2600n printer has a 51.22 error even after removing the toners
The device has experienced an internal
hardware error.
51.22 Error-magenta scanner error
try this:
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine.
Oct 30, 2010 | HP Color LaserJet 2600n Printer
1 colour is not working
check software first, check your magenta cartridge, Download service manual from the internet to fi the problem from eserviceinfo.com ,
it is great
Mar 14, 2010 | HP Color LaserJet 2600n Printer
550.1 error
I'm assuming that the error msg that you typed is a typo. And you meant to type 55.1
55.1 is a DC Controller failure. Turn the printer off for at least 30 seconds. Turn it back on. After it initializes, try to print. If it fails again, you are going to have to replace the DC Controller
Jan 30, 2010 | HP Color LaserJet 2600n Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Engine comm error
reconnect your usb cable to printer to computer.then also try tochange that usb cable if pro remains.
Feb 09, 2009 | HP Color LaserJet 2600n Printer
Hp colour laser jet 2600n
This printer should still be under warrantee, can you take it back?
Oct 16, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
604 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
