Goodman CLQ36AR49 Air Conditioner Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an goodman model # gsc130241ae ac unit outside it will not come on, no hum, fan doesn't run thermostat control is good swaped out with downstairs unit. Gas heat unit is in the attic, I don't use this part of the unit during the winter because this is the #2 unit for upstairs. Downstairs unit works great circuit breaker is on
Paul
Level 2:
Novelist:
  • Expert 144 Answers
  • Posted on Apr 02, 2010
Paul
Expert
Level 2:
Novelist:
Answers
144
Questions
0
Helped
90863
Points
313
Does the blower indoors run and move air? if not it would mean that you don't have power to the furnace.
The 24 volt transformer in the furnace is used to power the thermostat and the control circuit on the A/C unit outdoors. Or you could have blown a fuse on the computer board in the furnace.
If this has helped please rate me, and If you need more help, give me some more info.
Thanks,
Paul
Anonymous
Level 2:
  • Expert 116 Answers
  • Posted on Apr 27, 2010
Anonymous
Expert
Level 2:
Answers
116
Questions
Helped
57717
Points
297
Does fan on indoor unit come on if so then 24v is fine check for power to out door unit on ac only usually 2 wires to out door unit check to see if call 24vac if you have a small meter or take side off and carefully push in the contactor with insulated object to make sure unit is cappable of running
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
1helpful
2answers
Outside AC unit not blowing - Goodman dk-36-1d
1. check to make sure your 220volts is there at disconnect box.
2. check if you 24volts at contactor at the outside unit.
3. if you got it all check the capacitor.
2helpful
The outside unit has power going to it but isn't
maybe it has tripped off on high pressure, as you have have said the fan is not turning so will cause high pressure. now assuming the problem is the fan is not running than check the condition of the condensator /capacitor for the fan motor. if the motors winding is still good replace the capacitor and try it ON.
1helpful
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
GSC130241AE Goodman Air conditioner does not restart
It could be a bad thermostat.When the unit isnt working does the tubing frostup? If you have heavy frost in the evaporator this could mean a leak or a dirty coil. Also make sure the filter is clean.
2answers
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
