There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
i would reccomed a new charger, and if that doesnt work, then the charge spot on the DS is probably damaged, and you should take it to a game shop to have it shipped out and repaired.
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
If the system is new enough than I would suggest taking it back to the store. If its too late I can fix it for you. You have a faulty circuit or fuse in a circuit. I can test and repair, standard work. If you have any questions please contact me at [email protected]
looks like you need to replace the AC adaptor , test the AC adaptor with a multimeter to check Voltage , if there is Voltage reading?? then you need to replace the battery. hope this helps & please rate, AJ
Hey everyone, not sure if this will work for everyone, but its worth a shot. my problem was identical to all the others here, a flash of orange and then nothing.
i thought perhaps those little metal contacts on the battery and the ds had build up a little corrosion, interrupting the charge. so, i took some rubbing alcohol and q-tips and gently scrubbed them clean, both on the battery AND the ds side.
After this, my ds has worked flawlessly. Hope it's the same for you!
