NetGear DG834G Router Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Enabling encryption dg834g - NetGear DG834G Router
Anonymous
Level 3:
  • Master 1,272 Answers
  • Posted on Apr 02, 2010
Anonymous
Master
Level 3:
Answers
1272
Questions
Helped
385059
Points
3713
Please perform the below steps to enable security encryption on your wireless router DG834G:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Hope this allows you to resolve the issue.
Regards
Anand
How to enable my netgear DG834G v4
By setting it up . Do you have the instruction manual this would be a good starting point. Although you did not give a lot of information I will offer you a bit of information. This router is an ADSL router so you need to have an internet service provider that can provide ADSL on your phone line. Once you have an internet service provider give them a call and ask them to guide you in how to set up ADSL and connect this dg834G router to their network. ADSL requires ADSL line filters on all phones. While you are setting up the ADSL you might want to also setup encryption on the WI FI settings security and give it a network name. in the router.
tip
Secure your Wireless Router - General Guide
How do I secure my wireless router? A general guide
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
This is a very general guide, which will use the Netgear DG834G wireless router as an example. As every router is different, you will need your user manual to get the most out of this tip. (If you need help with finding a manual, see ‘How To Find a Router Manual’).
Here are the details:
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1 for the Netgear DG834G (Note, there is no ‘www’).
Enter username and password at the prompt.
Netgear DG834G: the defaults are username: admin and password: password (or, for UK Sky users - username: admin and password: sky). Other routers – common usernames are admin or blank: common passwords are admin, password, 1234, or blank.
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities. On the Netgear DG834G – this option is under Maintenance > Set Password.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
Tip: Write the router login password on a label, and stick it to the router.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings. For the Netgear DG834: the Network Name/ SSID option is under Setup > Wireless Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key . On the Netgear DG834Gv3 it is labelled ‘Network Key’.
The network key should be a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers - eg, 451ThisisGooDFunforgEeks7899. It is case sensitive. (If you think your connection is likely to be hacked, pick a very strong network key.)
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you should see your wireless router with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
If you get stuck with any of this, consult your manual, or post on Fixya. Good luck with securing your router.
A word about WPS: WPS is a shortcut method to help you implement security on a wireless router. Consult your user manual if your router is WPS enabled, and you prefer to use WPS.
All information is offered as is, without warranty. If you choose to use it, it is entirely at your own risk. Thanks to all Fixya contributors who helped with this tip. Advice and links current at time of writing. Written by ‘eecom’, Jan 2009.
on Jan 10, 2009 • NetGear DG834G Router
Can connect to internet via cable but not wirelessly with netgear router
I understand that you are not able to connect wirelessly through the router DG834G. Please perform the below task to configure the required settings:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router's GUI by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
Please scan for the wireless network on your wireless enabled computer and connect to the network of the router using the security key as mentioned above. If the issue persists, then please let me know about the operating system installed on the wireless computers.
I hope this information allows you to resolve this issue. Please revert back for any more assistance on the same.
Regards
Anand
I need to password protect my router ,
I understand that you would like to setup password on the wireless connection of the router DG834G. Please follow the below steps to enable security encryption:
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Please use the password as set above on your wireless computers to connect to the wireless network.
Regards
Anand
My ipod touch wont even recognise the network? help!
Reset the Router and the encryption should be limited to WEP. post a comment if you need details as to how to reset the router and then change the encryption type.
Hi, I have a netgear DG834G version 3 wireless router. I want to buy a wireless printer, will this router support one? If so, have you any opinions on the best buy? Thanks
any wireless printer should and will work with this modem-router as long as it's wireless settings are configured right, if you already have a computer connecting to this router wirelessly then that means the wireless functionality of your router is working. you just have to know the wireless settings of your router such as the SSID or the wireless network name, the type of wireless security and the wireless security key or encryption key.. once you have a wireless computer and it wireless feature is enabled it will automatically detect all networks name or SSIDs around the area, that includes your modem-router's and neighbors'.. when you try to connect to the SSID of your modem-router you will be asked for an encryption key or a password to be able to connect.. that will only happen if you have enabled a wireless security on your modem-router.
My router wireless transmission is not working and the light (for wireless transmission) is not coming on. All other wired connections are working. How can i fix this?
which version of dg834g do you have
its its v5 then it has a button located on top of it that enables/disables wireless connection
maybe you accidentally disabled it
if its any other version of dg834g the you can enable wireless transmission through the router page
Connect to the router by typing
http://www.routerlogin.net in the address bar of a browser.
if it asks for the id and password enter
id = admin
password = admin or password or leave it empty
these are default id and passwords, if you have changed them enter the id and password that you know
go to Wireless Settings
click on the checkbox that enables wireless transmission
save settings
and you are done
Encryption key?
Press and hold the reset buten for at least 30 seconds, this reset the router to factory default.
Then its just all over again, but do remember - by cabel, NOT wireless.
Please vote if this was helpful.
HOW DO I ENABLE THE ROUTER
reboot router ,ensure the encryption key is the same at both ends of the wifi link.ensure that remote device is wireless enabled.ensure that devices are close renough for a good signal,experiment with positions.
WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
