for sending text messages :
1. call to your network operator customer care 2. request the message center number... 3.note it down 4. go to message settings>message center number 5. insert the number which is noted by you and save it
this solves your messaging problem ... Good luck
Try flashing your phone. Install NOKIA PC SUITE and NOKIA SOFTWARE UPDATER (google them and select them from the Nokia websites) on your computer. Then connect your phone via the USB cable. Once the Nokia PC Suite finds and instal your phone, then run the Updater. It should allow you to install a higher version or the same version of your software. If you like to keep your data, you can use the nokia PC Suite to back up your entire phone before running the Software Updater. Afterwards use the same to Restore your Data. Make sure your phone is fully charged before doing this.
Did you accidentally dropped the Nokia E65? Well, on this error, you shoudl bring your unit to a service center to further check the hardware error such as the microphone. However, be sure that whenever you make calls you have the network signal high so that you can have quality voice calls.
This happened with a phone that i used to have and after a while i figured out that sometimes the messages just don't go through and that if i sent it a second time, it would go through. It seemed to me like my phone got too busy and some of the messages just got delayed.
