If no lights r on your display then your control module is proberly faulty. why did u change diverter valve and drain pump? please reply 4 more help.
sorry to hear that your controller went dead again. is it the brown controller. did u check water valve, motor, sounds like u have a faulty componet that is causing the fault. please reply back if u want to try and find fault. i will help as much as i can.
sorry it took me awhile to get back to u, my computer was playing up. now to test this unit, first get a test meter. select. ohms scale . go to the water valves up top of unit .their ohms reading should b about 63 ohms. next test your pump. it should b about 35 ohms. next test your motor. between any 2 of the windings the reading should b about 33ohms. next test your diverter it should b about 75 ohms, check with your old one and compare. now by memory u have got lid lock on your machine, the reading should b about 65 ohms. if u do these tests reply back and let me know. please turn power b4 you work on it.
I had a leak in the pump so i changed it. So when i was doing pump i changed diverter valve to. From the last time i posted this i did buy a control module. The same thing happen, it work then went dead, ithink i am going to give up. Putting to much money in it.
Yes i would like to know what went wrong. I had new water pump and diverter valve put in.
