Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: 6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
SOURCE: Display Shows Error 6A00 and it Doesnt Work ahead
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Solution Canon Pixma IP4300 Error 6A00, this
reset tips is from someone in printer forum but the tutorial in
picture. You can follow the instruction in the picture to solve error
6A00 in Canon iP4300. Some users say on the forum this reset method also
work on Canon iP4200 and Canon MP800. Look the picture below to view
the complete tutorial how to solve Error 6A00
Larger picture here
An error occurred in the AP motor
during purging operation.The parts you need to replace are :
-Sheet feed unit
- Purge unit
- Logic board
