Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
My 36" trinitron tube tv is 10 years old... Its a great tv .. but lately the screen has been going black randomly while the sound stays on... is the tube going?... is it worth fixing? I don't like the new plasma's and I would fix this tv if I could (within reason)
Girish Bhat
    New Friend:
  • 106 Answers
No ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Posted on Apr 02, 2010
Testimonial: "Great response... I basically needed to know if it is worth fixing (if its the tube) I like this tv and don't want to ditch for a new flat screen. thx"
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Sony Vega Screen Goes Black and then back to normal picture
Hi There,
Does it seem to be staying black longer? Are there any unusual sounds associated with it?
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Color adjustment on Sony 36" Trinitron
Unfortunately, the CRT (Picture Tube) is reaching its very end. Your set is not feasible to service even if the CRT would still be available from Sony or any jobbers.
I would be seriously shopping for a new TV set!
Jerry G.
Oct 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
20" Trinitron Wega
Good day.
First, Have your tv 's circuitry be resoldered. this might be a case of loose contacts particularly along the crt circuitry. the longer you operate the unit at this condition, the faster you are counting the possibility of shortening the lifespan of your tube. 9 years is quite a young age for a unit which has an average of 18years.
response is highly appreciated.
chris
Mar 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Jan 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Message on tv screen
The text mode in the closed caption is turned on.Turn off the closed caption.
I don't have the schematic in front of me, so, I will wing it.
There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the customer menu and you may have to search a bit.
Either way it's an easy fix and you can do it yourself.
If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Jan 02, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
Apr 08, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
WEGA 36" : Screen is low contrast and green
Sorry to say, it sounds like a bad picture tube, But could be also the capacitor that filters the screen voltage on the crt drivers. In all my years though, your complaint has been the picture tube. Good Luck.
Jan 02, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
