When I play my windows media player, it says no audio device is installed. In went to my computer's device manager and i've sen a yellow question mark in multimedia audio controller. what will i do?
Install or update the audio driver
Mercury p1 945 v-1.0a 15-v33-01109s realtek audio driver RTL8100C 83219A1
The yellow question mark means there is an issue with the audio controller or the drivers to make it work. Try uninstalling the drivers through the add/remove software applet inside control panel. Then remove the audio controller from hardware manager, reboot the machine and then re-install the drivers for the audio system. You can download the drivers from the mainboard manufacturers web site, just make sure you download the correct drivers for your operating system and audio chip. If you still get the yellow question mark in hardware manager, you may be trying to use the wrong drivers or you my even have an issue with the audio chip itself, as in it's damaged and will not work. However, most audio issues are due to drivers so try re-installing those first.
u need to check the sound driver on>try this
right click-->my computer-->and properties-->hard ware-->and device manager-->and audio devices-->right click-->properties-->and click-repair-->or trouble shoot>and rebooot teh pc>and try
once u went to the device manager on teh audio device u can see red X mark or some thing which means the driver is not loaded try this rate me solved>
