Question about Canon PIXMA MP830 All-In-One InkJet Printer
Scanner won't work
My computer has been working with the scanner and printer just fine, suddenly it will not scan. Nothing has changed, but now the scanner will not go through it's usual start-up routine, or do the "adjusting lamp" routine when I try to begin a scan. It is not "locked". There is no light, as well as no movement of the scanning bar.
  • 4 more comments
  • JosieJones Apr 17, 2008
    I have the same problem.
    Have troubleshot endlessly and cannot find a solution.
  • Anonymous Apr 18, 2008
    When I try to scan I get a message that says "waiting for lamp to adjust". The light is on, the bar won't move and I don't know what's wrong. I've had this machine for a year and now that I'm ready to scan, nothing happens on the computer or the scanner. It prints just fine. I paid too much $$$ to have to go through this.
  • clubdude Apr 23, 2008
    I have the same problem scanning, whether I initiate it from MP Navigator or from the control panel of the computer. It keeps giving me the "cannot connect to computer, error 155.00". Also on the machine itself, it won't stop "scanning" (even though it isn't) until I shut the MP830 down. I get all the messages mentioned by others, and it works great printing, copying, and faxing. I'm on Win XP Home Edition. Thanks.
  • Anonymous Aug 30, 2008
    When I initiate MP Navigator, my computer gets stuck on the adjusting lamp phase. It does not move and no light adjustment occurs. After several minutes, and then gives me a scan failed with code 2,178,0
  • Anonymous Mar 15, 2009
    Lamp won't light, won't copy or fax. It appears that the scanning lamp is out.
  • kelgra May 20, 2009
    The scanner just won't work (It used to.) The light doesn't come on, the bar doesn't move. I don't get any error messages. Everything else works as well as can be expected from this machine.
4 Related Answers
Anonymous
  • 4 Answers
SOURCE: scanner setting on canon pixma mp450 will not work.
Download drivers for PC or Mac from the official Canon website:
http://software.canon-europe.com/products/0010249.asp
Good luck! :)
Posted on Aug 15, 2008
Anonymous
SOURCE: HP officejet 4100 series all-in-one Scanner not working
tengo problemas de compactibilidad ente los istaladores de la hp 4110 all-line one con windows vista que hago
Posted on Mar 12, 2009
Anonymous
SOURCE: Sanning problems for multi function printer PIXMA MP 160
Just hold the stop and reset button until the warning goes away. Works like a charm
Posted on Feb 11, 2010
darius sanders
SOURCE: Scan problems with Canon MX310
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Posted on Dec 22, 2011
Brother control center 4 won't open on my computer
This may help others with scanning issues:
I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Apr 17, 2013 | Brother DCP Office Equipment & Supplies
I have used my Canon mp610 printer/scanner for years with no problem, now all of the sudden it will not scan. I know the computer sees it because I can print to it. I have restarted the printer and the...
In exactly the same boat. Navigator software worked fine for a long time, now it can't find the scanner driver. The only change I can identify is that I attempted to use Acrobat Pro for scanning and then nothing worked. Help!
Aug 09, 2010 | Canon MP610 Photo All-In-One Printer
Can't get scanner to work.
What you need to change is your screen resolution to either 800 x 600 or to 1024 x 768 (in your desktop settings)
You will NOT have to restart your computer either.
Just restart your scanner program and you can start scanning.
At least that's my assumption, though you might have bad cables, or an incompatible program.
Jan 07, 2009 | HP Officejet J5780 All-In-One InkJet...
Epson CX4200 scanner
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan.
Jul 10, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Scanner
Try scanning from the Kodak AiO Home Center software. If that fails, you should get better feedback. Unfortunately, I have run into this when my ink is low. While it should not matter, is does. Check to see if you need to replace a cartridge.
Good Luck.
DigiChick.
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Computer would not recognize the scanner
go to control panel, add hardware, search while the printer in connected, as far as im think you computer has disabled it. all you have to do it activate it.
May 12, 2008 | Office Equipment & Supplies
Brother MFC-640CW All-In-One InkJet Printer Scanning Issue
The first thing to do would be to download and reinstall scanning software and drivers on pc, something there is missing / changed I would guess.
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
201 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
