Theater Research TR-2810 Main / Stereo Speaker Logo
Lisa Sundstrom Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The sound is verey low
What typ of home stereo does the speakers need to be hook up to. if i dont have the same brand of stereo as the speakers.
  • Larry Stiles
    Larry Stiles Nov 26, 2014
    Any 8 ohm home speakers will work fine.
Anonymous
Level 3:
  • Master 417 Answers
  • Posted on Apr 03, 2010
Anonymous
Master
Level 3:
Answers
417
Questions
6
Helped
179059
Points
1147
Http://www.ripoffreport.com/Stereos/Theater-Research/theater-research-the-van-speak-73z89.htm
1helpful
How do i get the external audio output to work?
First make sure that your TV has an audio OUT. Most do not. If you do then you can plug into that but you will have to go into the menu on the TV under audio and turn on the external speaker feature. If you do not have an audio OUT then you will have to hook you speaker to the audio OUT of your home stereo system and hook the source output to the input of your stereo. Source being (dvd, cable box). In that case you need to turn off the internal speakers on the TV and just run it through your home stereo system.
1helpful
2002 Pontiac sunfire front and rear left speakers not working ! Any idea what could be wrong ? I heard there is a factory amp do you know where that would be and if that could be the problem
factory amps are located on the stereo unit itself or in the trunk but only if the car was ordered with premium sound and the possibilities of that car being ordered with premium sound is unlikely. so at the harness in the back of the stereo find the speaker wires and hook up a 9 volt battery to the said speakers that dont work if they crackle then its in the stereo if not its the speakers or wires to speakers with battery hooked up and speakers dont crackle go to speaker and test with a vom and test for 9 volts dc
I have a sherwood stereo receiver s-7100 I want to know how to connect speakers that have a rca typ plug to the receiver
WHY? Speakers with RCA plugs are notoriously low-end and intended for specific same-box amplifiers.
If you must: Make sure their impedance is at least 6-ohms. Lop off the connectors, strip the wires and boogie. Keep the fire extinguisher handy.
Hello my name is Scott and i just bought an Epson 8350 Projector now I was sure that i thought of everything to ask but when i brought it home i realized that my stereo surround sound receiver does not...
Dont worry, it doesn't have any speakers, so you casn listen to the sound in your stereo system which you will need to connect to the audio out of the player
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
Tried to hook surround sound to home stereo system and shorted out. home theater comes on but no sound to surround speakers
I need to know what system you are using, what speakers you want to use, and what decoding system you want to use...accordianman
Boston 746 speakers
they might have had a mini amp installed in each speaker some models of speakers have that feature to where u have to hook up power and also the regular speaker connections to the radio system basically even if you have a radio with some power then the speakers may have some type of crossover or something that makes it so if u dont have the power hooked up to them then they wont work right... but there are some speakers out there that dont do that, or it could be that if the stereo that u r using may just be that it has barely any output so it doesnt power the speakers... option 1, if it is the stereo then u will eather have to go to a car shop that sells the self powering speakers "not as cheap as regular speakers" and get those or, option 2, which consists of having to install a new stereo system with more power "remember the system hass to have a little more power than all the speakers combined together..."
2answers
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Top Theater Research Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Theater Research Audio Player and Recorder Expert? Answer questions, earn points and help others
