RCA RTD255 DVD Home Theatre System System Logo
Posted on Apr 02, 2010
I don't have universal remote code for my rtd3131 dvd home theater system
Jocelynn
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 14, 2014
Jocelynn
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
913
Points
0146. I found the code labeled under Audio. GE Universal Remote
5 Related Answers
Anonymous
  • Posted on Jul 02, 2008
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Anonymous
  • 3130 Answers
  • Posted on Oct 15, 2007
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
massiel
  • Posted on Dec 04, 2008
SOURCE: venturer universal remote code
The code I used is 0449...I have a STS20-S Venturer Home theater
Anonymous
  • 247 Answers
  • Posted on Jan 08, 2009
SOURCE: Can't find the code to program RCA RTD207 dvd home theater system
try these codes:
  • 178
  • 184
  • 205
  • 218
  • 224
  • 228
here is another way to program the remote:
  1. turn the device you want to set
  2. aim the reomte control at the device and press and hold down the code search button for at least 3 seconds until the red led lights up solid red
  3. press the device button you wish to program tv, vcr, dvd,etc and the led light will blink once and then remain solid red
  4. press on/off slowly and repeatly until the device your trying to program shut off
  5. once this occurs press enter button to store the code and the led light eill turn off
thanks
tom
Gurudristi
Sachin
  • 98 Answers
  • Posted on Mar 05, 2009
SOURCE: searching for home theater system remote control codes compliment
Here is the link for you to find the codes for an RCA remote.
http://remotefinder.rca.com/default.aspx?site=rca
I hope you are looking for this one. if not , please do let me know.
Please do rate this solution and thanks for using FixYa!
RCA RTD3131 5 diget code for direct tv remote. i have tryed all that they have on the website, both for the dvd, and the audio sound system. none work
None will. Logitech makes the Harmony remote. It will control all your audio components and never goes obsolete because it programs from their website at start up and whenever you add or change a component. It may seem pricey but you'll never have to buy another remote.
I am trying to get a universial remote for this dvd home theat. rtd 3131 i dont have the orignal remote and need a way to turn it on and off so i have tried a few universial remotes and still can seem to...
Universal remotes often do not have all the functions of the original. Sometimes they don't work at all on a product. You may find it necessary to purchase a replacement original if you want to get your system going again. You can try ordering one through the manufacturer's website, or from an online remote-control vendor. A Google search for "replacement remote control rca rtd3131" turned up several. Here are a couple picked at random: one site, another one.
Sorry I can't give you better news, but that's always been an issue with universal replacements. Thanks for using Fixya!
Universal remote
You can try a code seach which many universal remotes will do, this may be called auto search, if you have the manual for the RCA see if it is listed, instead of entering a 3 digit code, you cycle through all codes until the correct one responds to the unit you are trying to program.
1helpful
Need remote code
Many codes are on the website of the universal remote manufactuer.
If not, just ask them.
I need a philips cl034 universal remote code for memorex dvd play
I have similar problem with a Philips CL034 Universal Remote and a Memorex MVD2047. The Philips/Magnavox codes listed at this link did NOT resolve the problem. I tried all Memorex codes and tried the "all coded step-through" method. http://www.universal-remote.net/philipsmagnavox.html The above is NOT a solution, rather a note on a time consuming attempt to a solution.
2answers
Need Universal Remote Code for Panasonic DVD Home Theater Sound System
Need a remote for a Bose CINEMATE Digital Home Theater Speaker System. Where can I find one?
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
