Question about Mintek DTV-263 26 in. TV/DVD Combo
My remote control has broken.
I have purchased a universal control which I have been able to code with the Mintek general code for DVD players 0644. This allows me to run the DVD and power the unit on and off but des not allow for use with any TV features. I have tried to code my control with the TV/LCD general code 0216 but the TV does not respond to the code. Does anyone know any alternate codes for the Mintek 26" HDTV/DVD combo? please help loosing hair over this.
Posted by agustinpulid on
Jeff Bonvallet
    Scholar:
  • 41 Answers
I would check out the Harmony 510 remote control. It may be a little pricey but it is the best universal remote on the market for the money. It also allows you to control your DVD unit as well as your TV without the requirement of selecting which one. Harmony remotes are activity based in the you pick what you want to do such as “Watch TV”, “Watch DVD” , “Watch VCR” etc.. Then It turns the appropriate units on and then sets them to the correct input. Makes it real easy once set up. Another advantage is the IR codes are stored on line and constantly updated so new products and codes can be added.
Check it out:
http://www.amazon.com/Logitech-Harmony-Advanced-Universal-Control/dp/B001F51G1Q/ref=sr_1_10?ie=UTF8&s=electronics&qid=1270172488&sr=8-10
Posted on Apr 02, 2010
I need a remote control for a mintek 32 inch flat panel tv with built in dvd.the remote control is a RC -600. where can I find one?
It's tough trying to find OEM (manufacturer's) remotes. You could purchase a universal remote and program it to your set. Mintek doesn't have many codes and I believe 259 should do it. Good luck :)
Aug 25, 2011 | Mintek LCD TV Progressive Scan DVD Player
Where can I purchase a remote for the dvd-1600 mintek?
You can purchase a replacement remote at the link below, for $27.99:
Mintek Replacement Remote Controls
An universal remote will work, but the codes may not be available. That can be a complication as you need to go through the remote programming procedure manually.
Better to buy the original replacement.
Feb 28, 2009 | Mintek DVD-1600 DVD Player
Ge universal remote code for mintek dvd players
You most likely will not be able to find a code for it because it is an off brand (not-so-well known brand) and most universals will not have codes for that brand. if your universal remote doesnt have codes for the Mintek brand or has them and they dont work then, sorry that remote will not work for you. you will need to try and get a different one. or try and get the original remote. you can try finding the original remote at ReplacementRemotes.com by typing in the model of the Mintek DVD player. or you can try Ebay.
Dec 22, 2008 | Philips Magnavox Learning Universal Remote
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
Remote code needed
20839 is the DirecTV & Access HD universal remote code for Mintek, Shinsonic, & US Logic. None of which brands are listed in my Yamaha RAV283 remote code list (uses 4-digit codes).
20717 is also listed for Mintek by DirecTV. Other brands with the same code on DirecTV remote are: Apex, Blaupunkt, GE, Greenhill, Initial, KLH, Nesa, & RCA.
Of those brands, only Apex & RCA are listed in my Yamaha remote's list. I tried all of the codes for those 2 brands under types DVD, DVD Recorder, DVD/VCR, & TV/DVD. None worked. It appears to me that only those 3 brands for 20839 share the same remote code settings. If your remote doesn't support any of those 3, I doubt you will be able to use that particular remote with the Mintek DVD-1600.
I hope my research helps someone with this, as it was unfruitful for myself. Good Luck!
Jun 15, 2008 | Mintek DVD-1600 DVD Player
Remote control
try the most economical solution first replace remote with a universal one purchased at walgreens or walmart.
Think about it remotes fall after being put down they are handled by llittle ones and overall they are used more than the actual buttons on the dvd player
Jan 14, 2008 | Mintek DVD-1600 DVD Player
Mintek DVD-2580 DVD
I might have what you want. The mintek dvd 2580 password " screen " looks like it wants four numbers, it wants five numbers.
And they are 88888 as set by the manufacturer. If you ever need the code for the remote control it should be 0717. I hope this helps.
Dec 09, 2007 | Mintek DVD-2580 DVD Player
Mintek tc code
The code is 0216. The problem is the universal control accepts the code, it still will not work.
Nov 15, 2007 | Mintek LCD TV Progressive Scan DVD Player
Parental Controls
I am having the same problem. I have a Mintek 2110, but lost the remote control. I found this code on the Time Warner Cable site. 2096. I'm going to try and plug it into my universal remote this evening. If that works, the default passcode should be 88888. That's what I remember my code being years ago.
Oct 06, 2007 | Televison & Video
Mintek DTV-263 26 in. TV/DVD Combo Logo
377 people viewed this question
Top Mintek Televison & Video Experts
Lee Hodgson
Lee Hodgson
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
