Question about Canon PIXMA MX310 All-In-One Printer
Ink absorber is full
The ink absorber is full, printer no longer copies or prints.
Posted by saadams07528 on
Anonymous
  • 240 Answers
Waste ink is full. The printer needs servicing. Can be done yourself, though EXTREMELY MESSY! And you'll need to find how to reset the counter, or just look here:
http://www.fixya.com/support/t1987764-canon_mx310_wase_ink_full_any_ideas
The waste ink pad is a huge and dirty job. It requires nearly full disassembly of the machine and full washing and drying of the waste ink pads. Resetting the counter without cleaning the pads will result in waste ink overflowing out of your printer and on to what ever the printer is on. As for printer disassembly, service manuals are not generally available for consumer grade machines, which means you're on your own. Having torn down many machine's myself I can tell you it takes time, patience and a good memory. Take good note of where everything came from and how it goes back together.
Posted on Apr 02, 2010
I need information why MFC J265W wont print or copy.
During a print head cleaning, the printer moves ink through the print heads. This ink has to go someplace, and that's to the "ink absorber". Now, this absorber is full and needs to be replaced or the printer could overflow onto your table and make a mess.
The part may be user-replacable, or require a service visit, I don't know.
Sep 03, 2014 | Brother MFC Office Equipment & Supplies
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Empty waste ink absorber IP4000
I found this at the Canon website. www.canon.com
I also have a Canon Pixma, seems my turn is up and coming too.
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Find a Service Location
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
Aug 25, 2009 | Office Equipment & Supplies
Absorber is full
Hi ....
Please vote if this helps .... Cheers :)
Jul 15, 2009 | Canon Pixma iP4500 InkJet Printer
Canon ip1800 ink absorber is full, cannot remove Cartridge
Hi ...
Please vote if this helps ... Cheers :)
Jun 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My Canon Pixma MP780 is saying "waste ink absorber is near full"
Under the place where the inks park is a tray full of asorbent pads. It was the most awful thing to get to in my Pixma ip 2000. If you have a day to spare, and a work table, and some long needle nose pliers or maybe hemostats, and the usual tools, you can take the machine apart to get at it. Note which pads (and parts) go where, everything has to go back where it came from. The pads will rinse out with water, lots of it.
Apr 29, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The waste ink absorber is almost full will not print
wait until the absorber counter full and reset it with this instructions
Mar 25, 2009 | Canon PIXMA MP130 All-In-One InkJet...
WASTE INK ABSORBER IS FULL FOR CANON PIXMA iP2000
The machine needs to be taken in for the waste ink absorber to be replaced
Oct 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon BubbleJet i320 Printer Problem
The Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
What you can do is:
· Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
· Ink Absorber Replacement Options
Jul 11, 2008 | Canon BubbleJet i320 Printer
Canon PIXMA MX310 All-In-One Printer Logo
926 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
